Question about Irons
Need parts and repair manual for Dayton model 3z773d electric steam cleaner
The valve that controls water to steam is missing
2 Suggested Answers
blkshk
  • 4 Answers
SOURCE: just a few months old and stopped steaming, steams frowater entry
I have taken one of these completely apart and found it is glued together except for the platinum plate on the bottom. It is held on by circular lock clips and will break w/o proper tool. I see no way to repair these and the cost of sending in will probably be as expensive as a new one. I have seen them at Lowes and TuesdayMorning for about $100.00. Have tried to get a repair manual from Rowenta-good luck!
Posted on Dec 29, 2008
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
My stream iron generator tefal and problem some parts outstanding on base of iron , and stream can not get out , how to remove PARTS.
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 02, 2013 | Tefal Irons
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
Steam iron turns itself from hot temperature to cool
1) test the electronic control for defective and follow the next steps. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jun 11, 2013 | Irons
As the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 02, 2012 | Irons
Tefal easycord gv 5140 no steam
do this. and use the common sense and KEEP the calm. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Sep 24, 2012 | Rowenta Irons
The temperature of the boiler is not controlled normally and the safety valve opens. I suspect that the temperature control sensor is not functioning properly, and if this is the case where can I find a...
see this causes and use the common sense. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Sep 19, 2012 | Rowenta Irons
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Sewing needle
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Mar 26, 2009 | Rowenta Irons
Irons Logo
74 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
