Question about General Heating & Cooling
My o general invert ore ac 2 ton blink green light after runing 15 mnts compressor.
  • 252 Answers
SOURCE: LG Window AC Problem
send it back again!
Posted on May 03, 2009
  • 3 Answers
SOURCE: My 5 ton Goodman Heat Pump won't go into heat or a...
Easy: Turn the "fan" switch to on at the thermostat and see if the blower starts. If no start, check breaker at breaker box. Check service disconnect at or near the air handler. With the breaker and/or service disconnect OFF check the 3 or 5 amp fuse inside the top cover in the air handler.
Not so easy: (You must know what you are doing for this part or let an HVAC Tech do it for you) Open thermostat and firmly jump the Y and R terminals to see if you get the compressor to start for no more than 30 seconds. (don't do it more than once.) Jump the G and R terminals to see if you get the blower to start. If so, u have a bad thermostat. If not, check the transformer inside the same cover in air handler for proper voltage. (24V. Make sure you also get 220 on the opposite side of the transformer)
If the blower comes on, but the heat pump doesnt start, open the side cover of the heat pump, with the thermostat on cool, and the temp. setting as low as possible for at least 10 minutes see if the contactor is pulled in. If so, check the capacitor and see if it's blown out. Be super careful these systems operate with 220v and the amperes are enough to kill you if you make a simple mistake.
Posted on Aug 28, 2010
  • 674 Answers
SOURCE: split a.c.1.5.ton, yesterday night stopped.
Somewhere on the cover or the circuit board there should be a chart that tells you what the different light combinations mean. Look around inside the unit and try to find the codes and you can also check the owners manual.
Posted on Sep 05, 2010
hvac1960
  • 2133 Answers
SOURCE: MY SAMSUNG SPILT AC 1 1/2 TONS SLIVER NANO
It means, someone set the timer to start the unit after one hour. To cancel, simple remove battery from remote and reset it. And also power of the unit and reset it. Now start your unit with remote.
Posted on Dec 16, 2010
hvac1960
  • 2133 Answers
SOURCE: misubishi split a c 2 tons green light blinking
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it.
If blinking 2 times, Indoor room air thermistor defective replace.
Thanks.
Posted on Feb 19, 2011
O general split ac indoor timer light 5 time blinking .what problem
There's a redlight turned on in the inverter of my O General 1.5 ton AC. What might probably be the problem? Please guide.
Jun 02, 2015 | General Heating & Cooling
Toyota tundra ac light switch keeps blinking
Wrong category Roger. Anyway I have read on a toyota forum that the ground wire on the AC compressor may cause this type of flashing green light of death. It was suggested the ground wire connection may be loose and the screw holding it may need to be tightened.
If your AC light is blinking check this first Toyota Nation Forum...
Jun 12, 2014 | Computers & Internet
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
Would like to know how to intall an air condition compressor
Firstly de gas the a/c system then remove a/c belt then remove the 2 a/ c pipes to the compressor then disconnect the ac clutch wiring remove the bolts holding the compressor to the cyl block fit new compressor replace the ac pipe orings Then refit the ac pipes reconnect ac clutch wiring refit belt. Then regas the system addind uv dye and comressor oil
Oct 04, 2010 | 2001 Pontiac Grand Am SE
I have a road pro rppi converter light links
It blinks because your computer is drawing too much current. Most of these give an exaggerated wattage range, and never give details about the true amperage available. the average laptop uses 3.0 to 4.X amps and is too much for these mini inverters. But they work fine on cell phone chargers.
Mar 24, 2010 | RoadPro AC/DC Power Inverter 80/100w
Screen is black. green light on ac adapter blinks briefly about every 2 seconds
Look for bad solder joints in the inverter circuits, look at the round inductors (4) leads soldered to the circuit board, post or send pictures for futher help.
Feb 02, 2010 | HP Pavilion F1703 17" LCD Monitor
Green and red light are blinking on roadpro 300 power inverter
if the inverter is working and the fan is just starting and stopping the fan must be bad, but if it is not supplying power the inverter control is bad
May 11, 2009 | RoadPro AC/DC Power Inverter 80/100w
Heating & Cooling Logo
133 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Bill Long
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
