Question about Yamaha RX-Z9 Receiver
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
I have a Main room with 6 surround speakers - however, it only plays out of Zone 2 (The system says Zone 2 on it). I don't even see MAIN which the manual says it has. I have 2 outdoor speakers on the B channel off the same Zone 2. They play fine also. I have hooked up 4 more speakers to an upstairs room. When I run the auto configuration I hear sound from 2 of the speakers but not the other two.
My question is, how to get speakers configured to Main, I think once I can accomplish this, I can resolve the other 2 rooms worth of speakers. I was thinking that maybe there is a reset, that I could basically start over with the configuration. Any suggestions appreciated.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Posted on Nov 30, 2008
Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Jul 05, 2009 | Yamaha RX-V463 Receiver
Trying to hook up Zone B stereo speakers in two additional rooms.
The infrared mentioned by the manual is most likely an extension possibility to use the remote control in each room, forget that part.
What you need to do is quite simpel, after connecting all speakers, you should indicate in the setup menu of each zone which speakers are connected and do as follows:
in main room select 5.1 setup, for the other zone select only the left and right front speakers.
Your EXTRA SP indicates the extra speakers for 7.1 setup and when set to zone B it recognises only 1 speaker.
So read carefully the manual how to connect Zone 2 speakers and connect that way, than carefully walk through the setup menu to setup the zone 2 correctly.
Apr 09, 2009 | Yamaha RX-V663 Receiver
Add 2 speakers outside on a 6 speaker surround sound and hear all
You won`t get surround sound mix with 2 speakers, you can have a 2nd zone but this will only play a "Stereo Sound" if you have that playback option with the SC-RT50, what you will need is a speaker selector switch or better known as an A & B switch, this will ideally run from the front left and right speaker output of the receiver into the A & B switch then run into each pair of speakers inside or outside, what is common nowdays are receiver that are known as 2nd zone connections where you can have 2 sets of speaker in different rooms, unfortunatly the SC-PT50 does not have this option.
Feb 03, 2009 | Panasonic SC-RT50 System
Yamaha RX Z9 and two-channel system integration
The A-B speaker switch is intended to direct amplifier output to a pair of speakers in a different location when set to B.
Feb 26, 2017 | Televison & Video
No sound out of surround back speakers
It sounds like you don't have your surround sound source set up properly (your DVD player is not set up for PCM sound).
the best quality audio will be to set up either digital or optical audio between the DVD and the receiver.
Once you have connected the optical or digital audio cable between the DVD and receiver, you have to go into the DVD player audio setup and change it to PCM digital audio or you will not get surround sound. DVD players are not set up by default to output surround sound.
Sep 05, 2008 | Yamaha RX-Z9 Receiver
Denon AVR 883 Audio glitch
More than likely the protector circuit is getting activated... You can't go below 6 ohms on the surround back which means you need 12 ohm or higher speakers for outside (since the two outputs for surround back/zone2 are in parallel). As a simple diagnostic test, disconnect one speaker and see if the sound survives longer than 2 seconds.
Mar 26, 2008 | Denon AVR-883 Receiver
RX-V661 Receiver
your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
Dec 29, 2007 | Yamaha RX-V661 Receiver
Zone 2 issues
Zone 2 only plays anolog inputs.
Aug 27, 2007 | Yamaha RX-Z9 Receiver
Yamaha RX-Z9 Receiver Logo
165 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
