Question about Singer Sewing Machines
Hi, I have a Singer Inspiration Model 4212, the bobbin case keeps popping out of place so when the thread is going around it, it jams and gets cut out so I can't even get to sew an inch.
I have already tried taking it out and cleaning our lints on the inside, put it back in place, but as it starts sewing it pops again out of place. Also something because of it popping out of place the needle hits it and it already chiped the egde of the right case teeth.I have had this sewing machine for 7 years, I use it only every couple of months, but want to start doing more projects with it, has been giving me this problem for 4 years now,but now is more frequent and is just frustating and time consuming, and instead of relaxing while sewing I just get stressed out. Can somebody help me?
    Problem Solver:
  • 5 Answers
When you hold the bobbin case there is a little lever to hold when you push it in. You make feel a sort of click when it seats properly.
Try turning the wheel carefully by hand to different positions as it
may not be sitting in when the book is not in quite the right position.
Posted on May 03, 2015
  • Singer Master
  • 2,963 Answers
I'd guess you may need a replacement bobbin case since the original may have a retaining spring broken.
2 Suggested Answers
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Posted on Mar 21, 2010
Thread tension not working
Bobbin is not inserted to spin the correct direction.
Also, it could be that the bobbin tension isn't correct either.
Feb 02, 2014 | Singer Inspiration 4212 Mechanical Sewing...
New Singer 1507 user - cotton jamming everytime
try this link for a free manual just in case you don't have one
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
if the fabric is real light weight you may have to use a stablizer
also check to make sure the needle is the right one for the fabric being sewed..
make sure the bobbin is turned the correct direction, try putting the bobbin in the opposite direction..
if the machine keeps jamming, take it back up where you bought it and show them what it's doing and see if they can help you..
Jun 20, 2013 | Singer 1507
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
The bobincase springs up giving no stitch in singer inspiration
Try buying a new bobbin case, it probably was damaged by jumping out of position.
May 06, 2010 | Singer 5050 Mechanical Sewing Machine
My Singer 507 sewing machine keeps on jamming up, the thread gets wound around the bobin and jams. I have thread the machine as in the manual. PLEASE, PLEASE could you help.
If you have the 507 with the grey or black plastic bobbin case you may need to undo the two screws on the right hand side on the silver bit and push it over to the bobbin case so it is tight or enough gap between the bobbin case and the silver bit about a thread width.
Apr 05, 2010 | Singer 5070 Mechanical Sewing Machine
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Loose Bobbin Case on Singer 4830
Your first step is to go to the Singer site and download your user manual -- it's available free. You need to check to make sure that you are inserting it properly in the first place. Please keep in mind that the bobbin does NOT turn--the thread unwinds from the stationery bobbin.
Next, I would manually sew using the hand wheel and no fabric with the needle plate off and observe what it's doing. You CAN replace the bobbin case if necessary.
Jun 30, 2017 | Singer 4830
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed...
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Nov 14, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Jun 16, 2009 | Singer CE-100 Futura Computerized Sewing...
Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Jul 29, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Sewing Machines Logo
82 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
