It has stopped changing the slides. It sounds like the motor is not functioning properly. Any advice.
  • 2,963 Answers
Probably needs lubrication on the mechanism if you can get to it. I'd suggest silicone grease if you can get to it.
Posted on Apr 13, 2015
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
The van was hit on the back passenger side resulting in a dent . The open door light along with the interior lights flashed when I hit a bump. I hear something that sounds like a fan continuosly blowing....
I think this may be the "closer" motor continuously trying to gain a positive latch--and unable to do so. This could be from a damaged latch switch.
The sliding door has three motors, a slide motor, a release (or unlatch) motor, and a closer (or latching) motor. The open door light and interior lights coming on seem to indicate that the "closed and latched" switch is sometimes open-- allowing the closer motor to continue to operate.
Another possibility is that the dent has changed the geometry of the door mechanism especially the draw of the pull cable. The slide motor has a sensor that pulses when it runs. The door management controller counts the number of pulses of the slide motor sensor to determine when the door is fully closed and then stops the slide motor. At that point, the closer motor operates to latch the door. If the cable geometry has changed, the door controller may be shutting off the slide motor prematurely and the closer motor cannot complete the latch.
Mar 28, 2011 | 2000 Honda Odyssey
My Kodak Ektagrafic AF-1 Projector just stopped advancing and reversing while I was reviewing slides. I had been using both forward and reverse buttons. There is nothing stuck in it. It will not advance...
The KODAK Ektagraphic AF-1 was manufactured from approximately 1971 to 1981.
The problem you are describing is most likely a broken cycle solenoid "link". The "link" connects the cycle solenoid to the slide change mechanism. The "link" is made of plastic, which gets hard, brittle & could break over time.
Parts are still available, but the repair process is a intricate one. My best advice is to seek out an Authorized Repair Dealer.
Aug 11, 2010 | Office Equipment & Supplies
Water filling so far then stopping showing error ef41
Kindly check the motor wires whether it is connected properly or not then check the pressure starter whether it is working fine or not if it is not functioning properly kindly change pressure starter
May 18, 2010 | Washing Machines
Gas dryer 12690. When stopping dryer in the
When the dryer stops and you try to restart it do you hear a buzzing sound? If you do then you have a overheated drum motor. Full of lint or bad motor bearings. If bad motor bearings only solution is to replace the motor.
Mar 29, 2010 | Kenmore Dryers
I have a carousel 700 projector that will not cycle to load a slide.
Given the age of your projector, it probably has a broken "Link". The "Link" is plastic, and mechanically joins the cycle solenoid plunger and the slide change mechanism. As the "Link" ages, it gets brittle & cracks, rendering slide change non-functional. The good news is there are still parts available (www.micro-tools.com), but it is a rather intricate repair. My advice is to seek out the help of a factory-trained repair dealer. Good Luck !
Dec 04, 2009 | Kodak Office Equipment & Supplies
Will not change slides forward/backward, remote focus ok,
Your problem is most likely caused by a broken wire under the control panel or a wire somewhere in the "cycle circuit" that is no longer connected. You should seek out a factory-trained repair dealer who has a schematic that can trace down your projector problem.
Mar 15, 2009 | Kodak 4200 Slide Projector
Ge dde6500gbl electric dryer motor will not start
check your thermal fuse.this is on the heater housing.
Nov 18, 2008 | Dryers
899 people viewed this question
k24674
