Question about Vehicle Parts & Accessories
How do i start a petrol generator with a remote throttle and a manual choke
When the key is turned on it just cranks but just cant run alone...please help
    Top Expert:
  • 45,410 Answers
Usually have to turn the fuel valve on first
Posted on Apr 13, 2015
  • 2,963 Answers
Owner's manual no manual? Try MFG website or email their customer service, or try
manualslib.com
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Turns over but dose not start, spark plug sparking ok
Check you have petrol if the bike has not been run for sometime replace the fuel. Petrol ages and causes all manner of problems.
Are you trying to start the bike but it has gone onto reserve, move the fuel tap to the reserve position then try to start it. If the above fails, then try these:-
Is the spark plug wet when removed. If dry it sounds like the petrol is not getting through. Try opening the filler cap and leave it open, make sure the kill switch is in the run position. Try starting with the throttle full open. Does the bike have a manual choke try to start with the throttle shut, choke off, then full on, then while continuing to turn over move the choke lever in stages from fully on to fully off. I find on my Yam TW125 (winter and bad weather hack) that if I have not used it for a while sharp twist the throttle a couple of times no more than a third of a turn. Hope this helps.
Apr 08, 2014 | 2009 Daelim Roadwin R 125 FI
Wolf 5000kva generator
Locate where the choke lever is for your generator (under the petrol tank), you ought to notice a star headed shaped screw connected to the governor shaft (if you bend and look closely further beyond the choke lever; still under the petrol tank) which is linked to the carburettor housing/assembly. You need to increase/turn clockwise (using a star screwdriver) on this screw.
Your generator engine sound will change/high a bit because the engine speed will increase.
Reconnect your 1800w chop saw (load) and see if your generator can "effortlessly" accommodate it without shutting down otherwise, increae the turns on this adjustment screw attached to the governor shaft till your generator operates/stabilizes with the load (1800w) connected
Oct 05, 2017 | Wolf Manufacturing Electrical Supplies
Rota Hoe Briggs and Stratton Engine
If the air fuel mixture is wrong, because main jet is locked or debris in the float chamber, that may cause inconsistent revs.
May 23, 2017 | Measuring Tools & Sensors
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
I own a 5000 watt generators the problem is generator starts with choke on however as soon as i start closing the choke generator shuts down, any ideal on how to correct
Get a can of carburetor cleaner. Drain the gas. Mix small quantity of fresh gas & carb cleaner about 50/50. Run a little through (it might not start, but crank it enough to get some solution through the carb.) If it runs, that's great, run about half of your solution then turn it off for an hour. Then run the rest through. If it won't start, then after the hour add a bit of fresh gas to make the remaining solution about 90% gas and run this through By the way, running the carb cleaner through the air intake will not fix this problem, because the gumming of gas is in the fuel line, float valve, needle valve - not in the air stream. Running carb cleaner through the air intake is useful if the throttle is sticking.. Good luck, Vote if you found this helpful, Al K
Jul 07, 2011 | Craftsman Electrical Supplies
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
I have a 7500 watt guardian rv generator and it is difficult to start if not used on very regular basis. It cranks but will not fire. If I go out and manually fool with the choke it starts. Obviously it is...
Before starting the genset remove the air filter and check the throttle plate on the carberator, it should be closed. If it is opened, then you choke coil is worn out and needs to be replaced.
Apr 19, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Wont start
Try this sequence. Pump up the fuel bulb until it gets hard. There should be something equvilent to a fast idle setting, then hold in the primer(electric choke) and finally turn the key and crank. When it tries to start go easy on the electric choke. You may want to see if the electric choke moves freely.
Mar 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Flooding
Yes its getting too much petrol , you will have to check the float pin, better to clean the carb.
Mar 07, 2009 | 2004 Aprilia Tuono 1000
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
