When I turn on the TV with remote, why does it make many attempts before lighting up the screen?
    Top Expert:
  • Televison & ... Master
  • 75,320 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 13, 2015
    Top Expert:
  • 51,191 Answers
Try new batteries for remote .
    Top Expert:
  • 43,131 Answers
The power supply could be failing.
    Top Expert:
  • 10,875 Answers
Make sure nothing is blocking the remote from seeing the sensor on the tv and change the batteries
My sharpe tv won't turn on the green light is on but it won't start and you can't turn it off or on with the remote or button. You must unplug it for the green light to go off.
Please attempt to bring up an internal image on the screen by pressing Menu button on TVs remote, and on the TV panel itself. Do the same using the Volume button to see if the volume bar appears. If they appear, check the cords of the sources connected to the TV; make sure they are secure, and not loose.
If doesn't appear going to need a circuit board replacement.
Nov 09, 2015 | Sharp LC Televison & Video
TV will not switch on using the remote or manually on TV
Shorted circuit board components. Contact any service technician or the authorized service centre for LG, to confirm. Troubleshooting to plasma TVs is really a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 16, 2014 | LG 50PX1D 50 in. Plasma Television
Led light blinking
It is likely that the internal power supply has failed.
Dec 08, 2013 | Element Electronics Element 40" LED 1080P...
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I don't know if I can make it any clearer. My remote RM-PP411 suddenly stopped working. It has new battries and the use mode light lights up when any key is pressed. I turned the STR-D685 on by hand and...
Please take these actions before we try yet another universal programmable remote 1. Clean the IR screen on your tv set. It will often appear clear in view with a reflective window which often has a black, blue, or red tint to it 2. Clean the same window on the programmable remote 3. From tons of experience, I've noticed that Sony tends to provide the most compatible remote for replacements 4. Please confirm with me which codes your attempting to use when programming, and type /model number of the universal remote 5. Keep in mind that the remote that does not work as a replacment may very well be exchanged 6. Only use approved batteries for your remote and keep in mind that rechargeable batteries account for 50 percent of electronic errors 7. If your old remote simply stopped working for no reason at all, then we may have a communication problem with the tv combo set itself. 8. Ensure that the tv set is ready and able to receive a signal by setting it to the factory defaults within the settings menu 9. If we know why your older remote simply stopped transmitting the signal, we will acheive a must faster solution 10. Please attempt a fresh set of batteries in the older remote to determine the root cause behind the transmission problem 10. Check your power cord for crimping, dents, or pinched underneath unit. Each of these activities will cause power to stop transmitting to your unit 11. the digital display is not popular for having problems. 12. Ensure that you press the power on button on the digital display firmly at an attempt to power the unit on. 13. If you still have not recieved power, we will continue to troubleshoot the internal portions
Jan 26, 2011 | Sony RM-PP411 Remote Control
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Can't turn on tv
Unplug the tv for 30 and plug back in.
May 02, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
