Question about Garden
Where can I buy a new filter for this mower? - Garden
  • 960 Answers
Look up a local lawnmower repair shop, give them the make and model, Im sure they will have one. If not, you may have to go direct to the Manufacturer.
Posted on Apr 13, 2015
Testimonial: "I've tried several lawnmower shops with no joy. I'll have to go direct to the manufacturer."
  • Steve F Apr 13, 2015
    What make is it?
Need diagram of a MTD walk behind mower with honda 160cc engine with ARCS option
Remove air filter cover. Remove air filter. Remove the 3 10mm screws mounting the air filter housing assembly and carb to motor. You will need new gaskets to install the new carb. Gaskets: 16221-883-800 2ea., 16212-ZL8-000, 16228-ZL8-000, and the gasket for the back of the air cleaner mount 17228-ZMO-000. You can buy the carb for these on line for about $14, 16100-Z0L-023. Most take a NGK PLUG BPR6ES.
Apr 02, 2014 | Garden
I have oil blowing out the air filter. Is it the head gasket? worth fixing?
possibly rings broken or Valve guides worn, if this is the case then I have found from experience that if the base of the mower is ok then it is better to buy a new motor and fit it to your mower, the engine will have 12 months warranty compared to a reconditioned motor with 3 months warranty
Aug 14, 2013 | Parks Optical 13.5hp Briggs And Stratton...
Tipped on it's side now will not start
If you tipped it to the left the air filter will be soaked in engine oil and will need to be replaced. Also top up the engine oil to the correct level. You can try to start it after topping up the engine oil with the air filter removed and check that it runs before you buy a new air filter. Regards Phil.
Apr 27, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Where to buy a new oil filter and fuel filter?
You can buy a new oil filter and fuel filter at the briggs & stratton website here are the exact links
oil filter http://www.briggsandstratton.com/engines/shop/parts-and-accessories/part.aspx?id={803C6266-A7A3-4F83-A56E-8148DE31F0F6}&cs=Intek%E2%84%A2+with+XRD+Series+(V-Twin)
fuel filter http://www.briggsandstratton.com/engines/shop/parts-and-accessories/part.aspx?id={7135A082-B7B4-4F72-B4AF-29FBEBB661C5}&cs=Intek%E2%84%A2+with+XRD+Series+(V-Twin)
Regards obliqueridge
Nov 19, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Where can if i find a replacement air filter for my 21" poulan mower? no one seems to carry them. It's a honda engine.
there should be a model number for the engine stamped on the mower somewhere. more than likely, you will need to buy the filter from a honda small engine shop as opposed to a poulan supplier. if you bring the filter in to your local honda equipment shop, they should be able to match it up quite easily. good luck!
Aug 29, 2010 | Poulan "Poulan" Push Mower
Oil Filter Removal
Hi the oil fiilter will undo to the left or anti clockwise how ever it may be tight as the rubber seal tends to weld itself stuck so you can eiter buy a oil filter removal tool or you can stab a screwdriver through the middle from left to right so as you can use to to undo the filter so if you have room to get a screw driver through the side of the filter then push the screwdriver through one side and out the other then use this to remove the filter doing this should free it up.
Now when you put the new filter on make sure you put some new engine oil around the rubber rub it on with your finger so that the new rubber on the filter is coated in new engine oil doing this will ensure its sealed properly and should ensure that you have no leaks.
May 31, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
My 2166 Cub Cadet pops and backfires at high rpm.
try replacing the air filter first or check it with the filter off, you may only need a new filter. if not get a mower or bike shop to test the coil they will let you which one to buy
Jul 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Oil coming out of the air filter
Sorry to say this is a enteral problem with the engine. Either valve guides or piston rings. Best solution is to buy a new mower, unless it is a expensive riding mower then you might be able to repair the engine for less than the cost of a new mower.I know you don't want to here this but I do believe it is the only way to go.
Kurt
Apr 09, 2009 | Garden
Cannot pull rope out to start mower
Bad news , Mower has sit up too long and the piston / crankshaft has become rusty and froze in place. (fix) buy some liquid wrench it comes in a can at your local hardware store...Tilt the mower onto its front wheels and remove the spark plug. Fill the Cylindar with the oil and leave it for a couple days. after a few days lean the mower back and attempt to pour out the left over oil. Then (Check Your Oil level) preferable replace old oil and pull choke..and start mower...if the engine is still frozen (Buy a New mower) 125bucks Sears.
Mar 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
