My cabrio washer turns on but doesn't do anything after that. Whats wrong with it
    Master:
  • 602 Answers
Turn on the water supply
Posted on Apr 13, 2015
  • Washing Mach... Master
  • 2,963 Answers
Owner's manual troubleshooting, no manual? Try MFG website or email their customer service, or try
manualslib.com
4 Suggested Answers
  • 1028 Answers
SOURCE: Cabrio f50 Error
if in warranty call a tech...the connection on the motor postion sensor is not making goo contact if you want to try..lean washer back remove large allen screw in bottom of rotor(flywheel looking dohicky) pull rotor of remove the 4 screws in stator (dohicky with all the wires ) carefully pull it doen ..pulling wire retainers down will allow better access..connector with all the brown wires ..release catch and pull the connector off and on 6-8 times this will help clean connector of any excess coating from factory reassemble and ck
Posted on Sep 06, 2008
Macmarkus
  • 2605 Answers
SOURCE: whirlpool cabrio washer showing F51 error code
Hi Craig,
Just saw this post come up among F51 error codes (as it will show previously posted and answered questions ) and wanted to add some info I have regarding this exact issue you may or may not already have, no harm in posting either way.
The F51 typically indicates a failed "RPS" has been detecected...but it can be the result of other issues...just for future reference and if anyone has not come accross this before.
The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how, thus the error F51.
**The repair tip below is directly from Whirlpool**
F51 is usually associated with the rotor and stator/RPS assembly and quiet often it is initiated due to a loose rotor or bad RPS...I'd start by checking the bolt.
There is a repair tip regarding this which suggest checking the wires to the RPS and then the rotor, while insuring the center bolt is really tight via applying some "lock tight".
I actually see a lot of these and most times it's a loose rotor bolt, that is where I always start my diagnosis. Here's an exert from my files directly from Whirlpool...
You may want to check the rotor, I've seen the center bolt become extremely loose, thus causing the F51 error, this is where and what to look for shown below...
...but either way that should help out with the repairs and good luck.
Regards,
Macmarkus :)
Posted on Dec 22, 2011
  • 14 Answers
SOURCE: Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Posted on Apr 03, 2013
Cabrio clothes washer codes f68 f84 f32 are shown
Before you do anything, Contact Whirlpool service with your model and serial number. There and many recalls on their Cabrio washers for control board problems.
Feb 28, 2015 | Whirlpool WTW6400SW Cabrio Washer
The lid lock botton is flashing and the washer wont do anything from there
there is a service technician data sheet that you will find very handy.
it is in a plastic baggy on the inside of the frame. usually left top. if you tilt the washer towards its back at a 45 degree angle shine a flashlight up the front panel, you will see it. this will walk you through a diagnostic test mode. It will tell you whats wrong with it.
Sep 19, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
My cabrio washer is leaking badly
Call the whirlpool factory and tell them you are calling about a recall, they replaced my motherboard for free to keep me as a satisfied customer. Doesn't hurt to give it a try.
Jul 29, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
What's your problem?my washer wont turn on
brownout lol, even if we say whats the problem u still need a technician to fix it.
Jun 29, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I rented a whirlepool cabrio washer and it is giving me F error messages with everything on the wheel hilighted whats that mean and what can I do if it is a rented appliance?
Rent to own or rent to rent washers are are fixed or replaced free by the rent to own company. Call em and tell them to send out another machine or a repair guy.
Sep 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Cabrio is showing "LD" in the display code and
you need to check your main drain pump for anything that may be restricting the water flow or stopping the impellar wheel from turning
Nov 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Installing a whirlpool cabrio washer lid switch.
See the following Whirlpool Service Manual for the Cabrio.
This should help.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
