Question about Coffee Makers & Espresso Machines
Starts brewing & then quits and the start blue button starts blinking.
  • 2,963 Answers
Owner's manual troubleshooting, no manual? Try MFG website or email their customer service, or try
manualslib.com
It's likely one of the safety Thermo disk type switches is bad, or some other problem that causes it to cut off. If the warranty is still valid with sales receipt proof, I'd return it. Or if not, the cost of repair may be more than a lightly used replacement.
Posted on Apr 13, 2015
Saeco problems
hi,you have the problem with the grinder.Usually it's happen when the brushes of the electical motor are gone. You can change them or change the grider.It's your choise.
Sep 04, 2014 | Saeco Vienna De Luxe Espresso Machine
Jvc rear projection tv HD56G787
There is a fault with its main digital board. Check it.
Jun 21, 2013 | Televison & Video
HOW DO I ADJUST THE 1-4 HOUR AUTOMATIC SHUTOFF TIMER?
Press the ON/Off button until it time on the clock starts blinking. Then where the clock is just set the time to what ever time you like for instance 2 hours just set it for 2 and wait for it to stop blinking or just press the on/off button again for it to stop blinking. Hope this is helpful to you. Have a great day
Oct 23, 2012 | Cuisinart Brew Central 12-cup Coffee Maker
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
How do you program?
Hello!
This could help
How to set the time:
1. Plug in the unit. Wait until the hour on the LCD starts blinking
2. Press the CLOCK button to set the correct hour
3. Press the SET button to switch to minutes
4. Press the CLOCK button to set minutes
5. Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
1. Press and hold SET until the hour begins to blink
2. Press PROGRAM until you see the tiny bell icon on the bottom of the screen
3. Press CLOCK until you get to the hour you want to start brewing
4. Press SET to switch to minutes
5. Press CLOCK to get to the minutes you want to start brewing
6. Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
Please rate this answer. thanks
Nov 24, 2010 | Faberware FCP512S Cordless Electric Kettle
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
The program light won't stop blinking
Same here. I'm dead in the water. This started happening a few weeks ago and with patience and luck and different combos of buttons I'd get it to stop and I was able to brew. Today it just stopped completely. The program light either blinks constantly or stays lit constantly, but I cannot brew coffee. I see lots of people online with this problem, but have yet to see a solution.
Dec 08, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Our 52" widescreen LCD TV just quit working.
This set uses a lamp ( not picture tubes ) The part # is TS-CL110U. Almost certainly it is bad. They are easily obtainable and you can easily change it yourself.
Apr 09, 2009 | JVC HD-52G787 52" Projection Television
Farberware FCP512S coffee pot instructions
Plug the unit in
Hope this helps
Sep 09, 2008 | Mr. Coffee ISX23
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Coffee Makers & Espresso Machines Logo
59 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
