Question about Lutron Electrical Supplies
Lutron lights in living room go from max to dim to max in rapid succession (2sec cycle).....is that something I can reset? (I suspect cleaner tried to put lights on and reprogrammed somehow)
    Top Expert:
  • Lutron Master
  • 44,436 Answers
Call the manufacturer tech support .
Posted on Apr 13, 2015
Hi Ive got a Lutron Grafik Eye 3000 controlling
I need more information. Are the fixtures pot lights? What kind of bulbs are you using? Floodlights, spotlights, incondescent (normal tungsten filaments) or fluorescent, compact fluorescent, led etc. Since most dimmers say in their instructions that they are designed for incondescent lighting only the bulb you use can either blow up the switch or cause troubles like you are specifying. Also inside pot lights are thermal cutoffs that trip and reset when the light is cool again. Can you remove the switchplates and see where it says incondescent only embossed into the aluminum heatsink? If it says something else, what does it say?
Aug 01, 2013 | Lutron Electrical Supplies
Lutron Dimmer switch, single pole, will not dim
We are truly sorry for your inconvenience and want to help. Please call our Technical Support line at 1-888-523-9466 and we'll be happy to discuss the issues with you.
Craig, Lutron Technical Support Leader
Nov 22, 2012 | Lutron #D-600PH-DK 600W SP Push Rotating...
I turn the power on push the ctrl button and push start, The unit turns on ready to start but does not start
Try reset first, If that does not resolve it, suspect the start switch as the culprit. You might be able to clean the contact surfaces with contact cleaner and rapid cycling of the switch.
Dec 28, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
I have a Lutron Maestro MAW-600 switch connected to 2 pendant lights and the 2 pendant lights bulbs blew. I replaced the bulbs but the lights still do not come on. The Lutron switch flashes green rapidly...
Lutron Maestro MAW-600 manual:
Single-Pole 600 Watt Halogen/ Incandescent Dimmer (minimum 40 Watt)
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
Lutron technical support 1.800.523.9466
You said pendant lights blew out.
How many total watts were those lights?
Did you remove aluminum break-away fins on side of device to match wattage?
Front indicator can be pulled out to cut power to circuit.
This is called FASS switch.
Try pulling out FASS switch and then pushing it back to see if it re-sets device.
Click breaker on-off to see if it resets device.
You replaced a single-pole switch that has two wires plug ground wire.
Each wire from switch goes to either screw on MAW-600 so it's hard to go wrong there.
Bare copper goes to green ground screw.
Otherwise, it looks like tech support is next step: 1800-523-9466
Nov 24, 2010 | Maestro Lutron MAW-600H Single-pole 600...
I have 3 hanging kitchen lights over the sink on the Lutron dimmer - 2 issues - The lights dim all by themselves and know one of the pendent lights is always burining the bulb out within a few weeks of use...
To separate any wiring problem from dimmer problems, temporarily replace the dimmer with a regular switch. Use it that way for few weeks if necessary. If it works normally with the switch, you need a new dimmer.
Oct 22, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Lutron dimmer problem
There should be no interconnection between the dimmer for the ;lighhts and the media power .. isolate the dimmer / lighting circuit and troubleshoot it separately,
Apr 12, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
When controlling a 300 watt cable lighting system
Sounds like a loose connection. If they all fo out, it's at the beginning of the circuit. Check all connections at the start of circuit.
Sep 01, 2009 | Lutron Electronic Low-Voltage...
Replaced existing Lutron skylark low voltage dimmer
You will need to return the 3-way dimmer and get a single pole dimmer, as the Lutron Skylark series is suspectible to failure if connected to a live circuit first, or misconnected at intial installation. As an electrician, I ceased using these dimmers years ago, due to the rash of call-backs by customers and went with Leviton togglers and have had excellent results.
If you purchased it at a 'big box' store, they will accept the return as a defective item, as they have national agreements with their suppliers to accept customer returns. Just tell them it didn't work and you want a store credit, you can then purchase the lower priced single pole dimmer you need and save some money in the process too.
Hope you find this Very Helpful - best regards!
Aug 18, 2009 | Lutron Electrical Supplies
I have recessed lighting in my living room with a dimmer i want install a fan with no lights on it
Do you mean you want to replace your recessed with a fan with no light? Try to visit www.contemporarylightingdecor.com, they have lighting and fan experts who could give free advice.
Jul 01, 2009 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
Open Questions:
Electrical Supplies Logo
239 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
