Question about Canon EOS 5D Mark II Digital Camera
My camera will not power up when switched on. The batteries are fully charged and I cleaned the terminals. The battery compartment is also closed. What else could I check myself?
    Sergeant:
  • 302 Answers
Switch off, remove batt, then replace the bat. You should notice a red LED blink. If that does not blink, you can't do much yourself. Take it in for a proper check by authorized service tech.
Posted on Oct 28, 2015
SOURCE: Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
Posted on Mar 13, 2008
darntoothysa
  • 489 Answers
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD600 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Posted on Nov 11, 2008
marked
  • 6487 Answers
SOURCE: My battery charger shows (green) fully charged when it is dead
THis is really a sign of a bad battery that is always being detected fully charge but its really drian , so it will be better for you to replace that battery.....
Posted on Dec 01, 2008
mannforever
  • 23 Answers
SOURCE: Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Posted on Aug 11, 2009
SOURCE: Camera does not switch on
Could be internal fuse.........Tricky
Posted on Jan 03, 2010
NIkon cool pix 5400 will not turn on. Battery is fully charged.
A couple of possibilities. The battery is bad and not accepting a charge. Replace the battery. The battery terminals are dirty. Using cotton swab and some isopropyl alcohol, clean then fully dry the metal contacts on the battery and inside the battery compartment. Before turning it back on, be sure everything is fully dry.
Jun 26, 2016 | Nikon Coolpix 5400 Digital Camera
My Coolpix s570 camera wont switch on
I noticed that you noted that you have a new battery. Have you fully charged it? Although batteries are charged before they leave the factory, you do not know how long they have been sitting on the dealer's shelf slowly discharging. The charging time for your EN-EL10 battery is about 100 minutes. Once your battery is fully charged, try to turn the camera on again. If it still doesn't work, you may have bought a defective battery, the battery contacts on the battery, the battery charger or in your camera's battery compartment may be dirty or the battery charger may be defective.
To clean terminals, rub a clean pencil eraser across the contacts. That will remove any dirt, grime or oils that may be preventing a solid electrical contact. Once the contacts are clean, charge the battery again and retry it in the camera.
If all that fails, contact the Nikon USA Service Center at 1-800-645-6687 9AM-8PM EST, Monday to Friday.
Feb 10, 2015 | Nikon COOLPIX S570 Digital Camera
Why will e10 will not turn on with new battere's?
Never use manganese (Zinc-Carbon) batteries in your camera.
Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Check the battery level from the camera and replace or charge the battery if necessary. Do not continue charging once the battery is fully charged as this will result in reduced battery performance.
Note that the battery may become hot during use; wait for the battery to cool before charging.
There can be more than one reason:
The battery can't be charged anymore, because it is defect.
The cable you use is defect
The charger you use is defect
One or more contacts are dirty or oxidised
Dirt on the battery terminals can prevent the camera from functioning. Should the battery terminals become dirty, wipe them off with a clean, dry cloth before use.
Don't forget to close the battery door correct. There is a switch preventing to use the camera when the door is not closed correct.
Jun 13, 2014 | Olympus Cameras
My fujifilm finepix s8500 froze when i was taking a picture and now it wont turn on
Just to make sure nothing else is wrong. Please remove the batteries, charge them complete. After you replaced the batteries wait half a minute. Always close the battery latch fully. (there is a little switch checking if it is closed correct, to prevent writing to the memory, when the battery compartment is not closed correct.
About the batteries:
Your camera will work with AA batteries.
Always be sure the batteries are charged. Every one of them.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
success.
May 26, 2014 | Cameras
Fuji finepix does not start
Confirm that the battery is charged
Confirm that the battery is inserted facing the correct way
Confirm that the memory card/battery cover is fully closed
Dirty battery terminals reduce battery performance. Try cleaning the terminals with a cotton swab and reinserting the battery a few times.
Check if there is no debris or anything else in the battery compartment that can prevent correct contact between the battery terminals and the connection points in the camera.
Nov 19, 2013 | Canon PowerShot SX30 IS Digital Camera
Camera won't turn on
If none of the suggested causes helps resolve the issue, then I suggest you bring it in for repair.
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
May 03, 2012 | Kodak EasyShare C330 Digital Camera
Sony dsc-s600
1= Use rechargeable battery cells and must be fully charged.
2= Check battery terminals in camera battery compartment. Must be cleaned and shiny.
3= Sony camera DCS-S600 won't charge batteries through USB cable plugged in PC. You need external battery charger to charge battery cells.
Oct 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Camera
Courtesy: http://photography-on-the.net/forum/showthread.php?t=151603
Jul 20, 2008 | Olympus FE-210 Digital Camera
Kodak easyshare z730
May 19, 2008 | Cameras
Canon EOS 5D Mark II Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
