I have a 40" Samsung LCD television which started clicking and making its musical turn on sound two or three times before turning on. Now two months after that it takes five to ten times for it to come on. Sometimes when it comes on it has a pixelation problem and half the screen is pink so I have to turn it off and on again. Once it is warmed upped I can turn it off and on with little to no problem. I am debating leaving it on 24/7 but then I'm sure to burn out something else out.
The gradual death you describe is probably caused by the decay of an electrolytic capacitor in the main power supply.
It would require a capacitance meter with loss measurement to ferret out the bad part.
Eventually, the supply will fail to start at all and leaving it on will cause the weak part to decay faster.
You might want to do some advance research on the cost of a replacement supply which you can probably replace on your own.
These are normally on a separate board that will be visually related to the AC coming in and will have larger than average components on it.
For safety, leave the AC disconnected overnight before you start doing any surgery; the power supply can deliver a nasty shock if not allowed to discharge.
I have a 32" inch tv that is less than a year old. The sound will come on, but not the picture....
(More)
I have a 32" inch tv that is less than a year old. The sound will come on, but not the picture. What can I do?
My television is a 42" Emerson. I went this morning to turn it on to watch the news &...
(More)
My television is a 42" Emerson. I went this morning to turn it on to watch the news & it turned on for about 4 seconds then turned off. H ow do i fix it?
