Question about Canon CanoScan LiDe110
How can unlock switch error code: 2,179,16
I want to use a 4 ports hub usb port
5 Suggested Answers
SOURCE: Printer going offline
How long is you usb cable? don't use to much long cable. better to use only 1 meter. because too long may cause error to your printer to pc.
Posted on Feb 09, 2008
  • 153 Answers
SOURCE: Error message appears "power surge at usb hub port" when I plugin
disconnect your usb hub and connect it directly to your computer and that will eliminate the usb hub if that is causing the problem,
I have worked on these machines a lot and very rarely do you have any usb problems, if it still is giving the same error message after by passing the usb hub, you will need to replace the main PCB on the printer itself
Canon Tech
Posted on Apr 13, 2009
t00nz
  • 4738 Answers
SOURCE: downloading images
Possibly a short in the camera, cable, or the port itself. Recommend trying another port. If that doesn't help, then please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Posted on May 17, 2009
adnanbhatti
  • 1188 Answers
SOURCE: A USB device has exceeded the power limits of its hub port
Windows display this message when a USB device is short-circuited. Try another USB cord or connect the usb to the port at the back of your pc. If it does not help then the problem resides in the printer. I will not suggest to dismantle your printer as there are no user serviceable parts inside.
Posted on Aug 10, 2009
Scans says it needs to be unlocked but already is.
To be clear, under the scanner, you have already peeled the seal stickers off, and slide the unlock slider from the lock icon to the unlock icon.
If your switch is firmly in the "unlocked" position and still get the error, then plug your USB cable into another port on your computer and restart. Make sure you are NOT using the USB ports on the FRONT of your computer and DO NOT use a USB hub. If the error continues, then there is a malfunction in the scanner and must be replaced.
Apr 22, 2010 | Canon CanoScan LiDE 500F Flatbed Scanner
Hp nx6110 laptop error power surge on hub port
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
Feb 16, 2010 | HP Compaq nc6120 Notebook
Is there a USB switch like a KVM switch? Where do I go for the best price on such an item?
All you need is a USB hub, I suggest you get a powered type because if any USB device you connect into this USB hub that draws excess power from the laptop, you will get an error power message. A powered USB hub does not rely on power from the laptop's USB port.
These USB hubs allow you to connect several USB devices at once. Most USB hubs have 4 USB ports.
Jan 28, 2010 | Lenovo ThinkPad X301 Notebook
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
USB Port has failed; 4E00:032B
Electrical surge on hub port. Either a device attached to the port, or the port itself, has drawn more current than allowed, and the hub turned off the port. The port will not function correctly until you reset it. If the device is the cause, it must be detached before resetting the port. To reset the port, disconnect the device, and then click Reset in the dialog box. If the port is the cause, close the dialog box, and do the following to re-enable the port:
Disconnect the hub.
Re-attach the hub.
If it is the root hub, unplug all attached USB devices from the computer, and (if they have power supplies) unplug them from the electric supply. After a few moments, reconnect the devices. The computer can be restarted at any time.-->
Dec 22, 2008 | Dell Inspiron B130 Notebook
Targus Travel USB 2.0 4-Port Hub with Notebook Light
I'm sorry to tell you your hub cannot be fixed. I have one just like it and have taken these things apart and repaired simple factory errors as loose wires and the such.
You should get yourself another Targus brand USB hub. They are good and quite reliable
Regards,
Worldvet.
Jun 08, 2008 | Targus 4-PORT TRAVEL USB 2.0 HUB...
Canon CanoScan LiDe110 Logo
313 people viewed this question
old marine
old marine
