Question about Toshiba e-Studio 350 Copier
How to remove power failure - Toshiba e-Studio 350 Copier
  • Toshiba Master
  • 628 Answers
Press Function Clear twice...
Posted on Aug 18, 2015
Machine will not power on
Possible failure of the main control board , remove the power and trace power to the control panel, if power is present then it is failure of the board, if not check the power cord, plug or inlet.
Sep 27, 2013 | LG Washing Machines
1 long beep 2 short beeps
Hello Hardyjosef,
Below is the beep code chart for the mini 10 systems.
No POST
If the system does not perform a Power-On Self-Test, there are various things to look for:
1.Check that the system has a power light.
2.If the system has no power light, ensure it is plugged into AC power. Remove the battery.
3.If the system has power but is not performing a POST, Check for one of the following Beep code errors.
Beep Code Description Failure Coverage
1 BIOS ROM checksum in progress or failure. BIOS Chip Motherboard Failure or ROM Error
2 No RAM Detected No Memory Detected
3 Chipset Error (North and South Bridge Chipset, DMA/IMR/Timer Error for Intel platform); Chipset Error Motherboard Failure
Time-Of-Day Clock test failure.
Gate A20 Failure
Super I/O Chip Failure
Keyboard Controller Test Failure
4 RAM Read/Write Failure Memory Failure
5 RTC Power Fail. COMS Battery Failure
6 Video BIOS Test Failure Video Card Failure
7 CPU Cache test failure CPU Failure
8 LCD LCD Failure
4.With the power off and the system unplugged, remove all CRUs from the system and reconnect the AC adapter to the system and try again.
Try reseatting the memory to see if that will resolve the issue. If not, the motherboard may be bad and will need to be replaced. If you need another motherboard you can call the Dell Spare Parts Department at 1-877-717-3355 to purchase one.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jun 25, 2013 | Dell Inspiron Mini 10 Notebook
N?o liga power off
Possible failure of the power supply section. You need to remove the SMPS section and check if there is a short or failure in the drivers.Please check this link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Dec 11, 2011 | Samsung DVD-R130 DVD Recorder
Dell e310 won't start after power failure ,orange
First up, don't buy a Dell again unless you like old **** with horrible support.
On Topic
- Did you pull out the keyboard and try another USB port (if it is an USB keyboard), or try another keyboard.
- If that doesn't work try clearing the CMOS (remove power plug, power on (to empty capasitors), either remove the CMOS battery and power on, or find a jumper to reset the CMOS. (since this is a Dell a that might not exist but check the manual).
Jun 25, 2011 | Dell Dimension E310 PC Desktop
When i went to bed, i turned the Daewoo TV off. Then when i tried to turn it on in the morning there was no power. No lights come on but the fuse is fine.
A total failure can be a result of a power failure in the TV. so to check the main power which is a SMPS unit - switch mode power supply- remove plug, remove the poser section and check;
check for tips on the link below;
May 19, 2011 | Televison & Video
My Acer 5630, suddenly cannot turn on. I already replace DC power adapter by a new one, but the problem still exist. Anybody can help me.
If you have already changed the charger, and tried running it without the battery, it sounds like you have a Mother Board failure. You should contact Acer and have it replaced.
Mar 14, 2011 | Acer Aspire 5630 Notebook
0xc18a0101
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Apr 21, 2010 | Office Equipment & Supplies
ON POWER UP SPLASH SCREEN DISPLAYS THEN FREEZES
I see failure in booting. I'm afraid your HDD has problem, have check with JVC Service Center near you, chances are high of HDD failure like you have that can be repair.
Feb 28, 2010 | JVC Everio GZ-MG130 Camcorder
The power turns on but it doesn't do anythigng else
It can be due to many factor
1.RAM not decting by Mainboard.
     remove the RAM & clean it's legs with a white paper and place it again & try.
2.SMPS failure
    Your power supply is not able to give the requirement of the PC due to mal-functioning.Replace the power supply & check.
3. BIOS failure
   Reset the PC BiOS to default setting by removing the CMOS battery.Check it again.
4.Motherboard failure
 Motherboard may have failed due to power spurge or spike.
Remove your processor & RAM and place it on another motherboard and check if processor & RAM are working or not.If they are working then it's motherboard fault.
replace the motherboard.
Dec 16, 2009 | Compaq Presario 5400US PC Desktop
Ink system failure
display says: "enter special key combo"
C. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
display says: "uiaux"
display says: "support COxxFN0723BR"
Perform the below steps:
Make sure that you perform steps from 2-9.
Please perform all the above steps from 10 to 13 .
Jan 06, 2009 | HP Photosmart C6280 Printer
Toshiba e-Studio 350 Copier Logo
76 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
