How do i set the regulator on my lifestyle greenhouse heater lifestyle greenhouse heater
Propane heater not heating
-Thermo is not working. Replace new thermo.
Good Luck
Mai
Dec 04, 2014 | Heating & Cooling
Instruction Manuals For Thermal Tempest TX3000 greenhouse heater
I need to service a Tempest 3000 greenhouse heater.Where can I get the data/ instruction manual for it?
Nov 15, 2013 | Washing Machines
My Dayton 4lz94 greenhouse thermostat doesn't activate at the set temp. But will turn on when temp is about 5 degrees below. Set temp. Is there a sensitivity adjustment to calibrate for activatio
I am having the same problem with my Dayton greenhouse thermostat, this question was posted in the wrong section...but if you find a solution I'd like to know. I am having problems with the heating thermostat as well as the cooling one.
Jan 27, 2012 | Ovens
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near...
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Dec 28, 2010 | Dayton Electric Heater
I need a new cable probe please
try ebay that is a good and cheap website
Jan 15, 2010 | Computers & Internet
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
No set-up for a Naan Irrigator greenhouse 8x6x7
try this link
http://www.naandanjain.com/e/Knowledge_Desk/Greenhouses%5B107%5D.htm
Jul 30, 2009 | Rion 8x8 Hobby Greenhouse
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
