Question about Champion G5NG853S Household Juice Extractor
Makes a rattling noise
Just bought this thing last night. Looks like new. only about 4-5yrs old and hardly used. Turn it on last night and it rattles inside the motor. Sounds like a bearing maybe. Please help. Thanks.
    Top Expert:
  • Champion Master
  • 42,850 Answers
Most likely the fan attached to the motor for cooling .try looking here http://erepairparts.com/
Posted on Apr 13, 2015
Testimonial: "Thanks but I searched in the link but couldn't find any parts for the champion??"
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
Excessive vibration and rattling when I have less than a cup of juice extracted.
I've had an Acme for 21 years and I don't care
what anyone tells you-they vibrate. After years
of trial and error I found mine vibrates less with
a worn blade that I sharpen with a drill. With
a new shredder blade you actually have to file
down the cutting burrs about one third and
adjust the blade to chute gap by unlocking
the adjusting screw on the center of the bottom,
turn it clockwise until blade contacts chute, and
back it off a half turn. Apparently with a slightly
duller blade, smaller gap, the produce goes through
more slowly and evenly. Also severe vibration will
cause the blade to jump up and chip the chute.
Dec 24, 2010 | Acme 5001 Supreme Juicerator Juice...
Using only 1 apple cut up into small pieces,3 stalks of celery and 10 small carrots, BEFORE I even get half way through, the machine is making such a racket because it has not distributed the pulp evenly,...
No insult intended, but if you're not mechanically
inclined forget about it. I've had one for 21 years
and a new blade makes it vibrate worse. if you
are handy contact me at jhnjohnp@cs.com.
Aug 06, 2010 | Acme 5001 Supreme Juicerator Juice...
Cecilware frigodrink loud rattling noise
Two of the sping are not work
Apr 20, 2010 | Juicers
AMCE JUICER WON'T WORK
4 SCREWS HOLD THE BASE PLATE.
REMOVE IT AND HAVE A LOOK. THE
WIRING IS PRETTY SIMPLE. THIS THING
IS REALLY BUILT, SO IT MIGHT BE SIMPLE
LIKE YOU SAID. MINE IS 19 YEARS OLD
AND I HAVE PARTS FOR ANOTHER 19.
May 19, 2009 | Acme 6001 Juice Extractor
Where can we locate a parts store?
The cutting blade can be found at http://www.waringproducts.com/ret/.  Waring now makes the juicers.  Good luck!
Mar 11, 2008 | Juicers
Acme Juicer
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
Jan 18, 2008 | Acme 5001 Supreme Juicerator Juice...
Damaged parts around the screw peg
I have the same problem but no such luck in resolving through customer service for free as suggested. I was told unless the purchaser purchased the extended warranty, the standard was 60 days only.
They were able to provide a complete new base for a tax total of $49.99 inclusive of shipping. This is not such a bad deal relative to purchasing a new one.
If I were to buy one new today though, I think I would research an alternative product since this design is flawed and they obviously are not interested in solving it and producing happy customers.
I am certain there are others that produce a good machine and will stand behind their designs. My internet research revealed many people suffering from this same problem.
I had the customer service rep review this page and thread with me while on the phone and he did not seem to care a whole lot. He further stated that the threaded white piece is not available as a replacement part; only the entire base as priced above.
So anyone researching to purchase a Jack Lalanne power juicer take note of how they stand behind faulty or flawed designs. They are not fully commited to the "outstanding last a life time product" like their marketing implys.
Darwyn
Nov 21, 2006 | Jack Lalanne Power Juicer 250 Watts
Champion G5NG853S Household Juice Extractor Logo
516 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
