Question about Canon ImageRUNNER 2018 Copier : 2018 Copier 18-cpm
My copy machine 2018 bring white paper
When i copy and sheet that bring paper with out character white paper what i do
SOURCE: 2nd side copying jams with multiple sheets of paper
asa
Posted on Jul 04, 2008
SOURCE: My copy machine will just print a totally black
Pull out your toner cartridge, push back the drum shutter and see if the drum is coated in toner. If so, it is defective. Replace it and it will be fine.
*please rate me ;)
Posted on Mar 21, 2009
SOURCE: Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Posted on Mar 26, 2009
canontech
  • 1219 Answers
SOURCE: COPIES PAPER BUT PRINTS BLANK SHEETS
You probably haveing poblems with laser shuter. call service
Posted on Feb 15, 2010
SOURCE: does not copy. the sheet
Can you please give more details.
If you moved the contrast slider darker and it still doesn't work, one solution is the end part has snapped below where the resistance dial is on circuit board. You'll have to unscrew panel to access circuit board. Not difficult but time consuming.
Please check that lamp is not dead.
Check all the coroner wires.
Is the supply of toner flowing or somewhere interrupted.
Take a piece of papaer and write all that's happening.
(for others to solve).
By doing this, you may stumble on something that's not working.
Keep in touch,
Fonda
Posted on Sep 20, 2011
When printing black dots appear chaotic, over the entire sheet of paper. What to do?
If the black dots appear on every sheet of paper it could be the fuser unit is wearing out or the drum unit. The way to check that is to stop a print half way through and remove the paper. If they are not there before the fuser unit but after it then it will be the fuser. Or if they are there before the fuser unit it will be the drum unit. If it they only appear specfic to one source then it is likely to be the source of the document. IE copying - check the optical area (scan glass etc). If on incoming Faxes it may well be the sender that has the problem and is just transmitting them to you. Hope this helps.
Sep 09, 2015 | Canon iRC2380i
Paper size not original and continuous sheet not working in tray.
be sure that tray paper measure compatible with machine soft ware
Apr 30, 2011 | Ricoh Aficio 2018 Copier
The outgoing faxes are becoming unreadable, any idea as to why this is occuring and what we can do to fix it?
I will look it up in the morning, I don't have that information with me at the moment, But there is a scanner calibration you can do to correct it.
You have to enter some codes and simply run white paper through the scanner to reset the values. But off hand I can't remember the exact numbers. I will get look them up and send it on here.
It is not hard to do at all. Will take about 2 or 3 minutes.
Jan 11, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
I have a Ricoh Aficio 2018 PhotoCopier. Recently it ran out of toner. I reinserted the old cartridge which I had re-filled with toner (ricoh). However the off-side (non-copy side) of the sheets are dirty -...
You probably have a toner spill which has gone under the transfer roller. Open the right side of the machine and you will see a dark colored roller on the inside of the open part. Stydy it very carefully and you will see how to remove the roller including it's holder. be carefull of the springs, they love to escape. also watch as to how the bushings and gears are assembled so you get them back on properly. Clean any toner out from underneath the roller, replace the assembly and run 10 copies of a white piece of paper. this roller runs on the backside of the paper and can cause your problem. Hope this works for you. Check your paper tray as well as toner can migrate down into them.
Dave T
Jul 27, 2008 | Ricoh Aficio 450 Copier
Copies from multiple trays
No, you will have to put your paper like you want( one sheet white and one sheet yellow and so on ) and put it in the same tray !
Mar 25, 2008 | Lanier 1205 Copier
Copying problem kyocera mita 3530
You did not specify how much of it it is NOT copying or left off.
Depends on how close to the end it is copying.
Try this make a copy of the ceiling ( open top with no documents and copy) it will give you a black sheet of paper, compare it to your copy, there is a margin of white around the black area this is because :
1- makes sure the toner is falling on the sheet
2- leaves enough room to clear out of the fuser.
Is your print falling in the white area? if so it can be adjusted but there has to be a margin of white around the paper. or it will cause jamming.
Good luck
Nov 15, 2007 | Office Equipment & Supplies
Canon ImageRUNNER 2018 Copier : 2018 Copier 18-cpm Logo
35 people viewed this question
old marine
old marine
