Question about Indesit KP9508EXG Dual Fuel (Electric and Gas) Kitchen Range
How do i replace the dual heating element - Indesit KP9508EXG Dual Fuel (Electric and Gas) Kitchen Range
  • Karl Frahm
    Karl Frahm Apr 14, 2015
    Hi the easiest is go to you tube and put in how to replace cooker element for model ..... have a pen and paper handy and when you open up the back of the cooker draw a picture of the wire connection plus colours. This makes it easier when you put all together again. Should take about 30 minutes to complete job. Not difficult at all..
My 4 slice dual it keeps popping the breaker
One of the heating element is broken and the heating wire which have live electricity is touching the body of the toaster and thus the poppong of the breaker. So you can use this link and check which is the broken heating element . You can buy one or more heating element from ebay there are only two kinds CENTER and END which you have choose from, they will aslo supply aslo replaceing instructions.
Dec 07, 2011 | Dualit 40352 4Slice Toaster
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 | Cooktops
I want to buy a replacement heating element
send me an email at iamjerin@live.cn , we are factory in China that produce heating elements. :-)
Jun 28, 2009 | Maximatic EDF-4080 Deep Fryer
Freezer keeps freezing up
You must change the defrost heater element, located in the back of the freezer compartment at the bottom. You have to remove the four screws, two on each side of the panel on the back wall of the freezer. The heating element located at the bottom has two wirers connected underneth on both sides of the element. The wires have female connectors which slide onto the male spades on the element, and can be easily removed. The single element heaters are now being replaced with a dual element heaters at the manufactures request. A refrigerator which I have repaired twice failed again when I replaced a single element with another single element heater after two years. I was informed only after a second trip to the same store to replace the part that General Electric suggested the dual element after they realized there were so many problems with the single element. I think G.E. should have factory recalled these units after they knew there was a problem. I also think I should not have to pay 38 dollars twice, and I should have been given the dual element the first time I had this problem!!!!!! I am a electronic and appliance technician and didn't have to pay for labor,But I am going to contacting G.E. about a refund for atleast one of my part replacements. I should been givin the dual element the first time. I recommend that anyone that reads this post that has had this problem do the same. My refrigerator was less than two years old when this problem first occured The dual element doesn't have to work as hard and will work much Longer!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 07, 2009 | General Electric GSS22JET Side by Side...
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
One of the dual element not heating up on a smooth top electric range
If this section was working before then it is either a defective switch or there is a burnt out section in the heating element - more often than not its the latter - the heating element would have to be replaced
Regards
Sep 22, 2008 | KitchenAid Kitchen Ranges
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
May 24, 2008 | Maytag MER5770 Electric Kitchen Range
Dishwasher element and thermostat
Check with multi-meter for power on heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck !
May 31, 2007 | Hotpoint 23 in. BF41 Built-in Dishwasher
Indesit KP9508EXG Dual Fuel (Electric and Gas) Kitchen Range Logo
63 people viewed this question
Top Indesit Kitchen Ranges Experts
Greg Cann
Greg Cann
Paul Carew
Owen Barnes
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
