Just ruined Expensive *** when the underwire got stuck during spin cycle.
The machine almost caught fire as sparks and smell was coming from machine. This has happened on two separate occasions over past week. Never happened In last 15 years? *** was in ******** bag.
    Top Expert:
  • Washing Mach... Master
  • 46,218 Answers
Guess it is time to buy a new machine
Posted on Apr 13, 2015
My washer is making a card stuck in bicycle spoke sound during rinse/spin cycle
Something has probably got behind the drum. Usual suspects are broken underwires from bras and hair clips or pins.
Spin it by hand when empty, both ways and see if you can figure out where it is at. Check the filter and the flexible rubber hoses from the drum drain point to the filter and the filter to the pump. Give those hoses a squeeze and see if you can feel anything in them. I have found bits of underwire, coins and small metal items. They are removable with a bit of effort, but be prepared for water spillage. Take a photo before you remove anything so you can see how it all fits back together.
Feb 03, 2016 | Maytag Centennial MVWC300VW 3.2 Cu. Ft....
LG 950 Direct Drive washing machine... Machine fills with water but does not start the cycle, it is trying to but then of course it doesn't, during its "trying" phase you can smell the motor working...
Check there is nothing blocked in the outlet pipes ...sometimes when wire (maybe from a underwire bra) gets in them it stops the machine from this function. If this is not the problem then it will be a programming one...
Mar 16, 2014 | LG Washing Machines
I have a Roper washer Model RAX4232PQ0 When it drains and spin cycle comes on it makes a very loud rubbing slash screeching sound and when we open it it smells like a burning smell Not rubber burning but...
Known problem:
A Failed switch Ark-Les part #8318084
Incident report on there website:
I have a Roper model #RAX4232PQ0 top-loading washing machine. The door switch wore out, short-circuited, and caught on fire. The machine continued to operate, so it took a little while to figure out where the smell was coming from. The failed switch is an Ark-Les part #8318084.
Dec 19, 2013 | Washing Machines
The underwire in my bra is stuck inside washer somewhere
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Aug 20, 2012 | Frigidaire Affinity ATF6000F Front Load...
My washer started smoking and smelling like burnt rubber during the spin cycle what needs to be fixed
Sounds as if your belt burnt up. Could be a bearing froze up or your belt broke and got caught on the pulley. You will have to look inside the machine from the back to see what it is. If the drum does not spin by hand easily it is probably the bearings
Feb 10, 2010 | Washing Machines
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Kenmore front load washer
Machine is draining slow...probably from debris caught in dain hose or pump filter. Many people find safety pins, loose change and bra underwires lodged in the drain trapping lint, threads and other items which are narrowing or blocking the drain. The machine will only go into spin if it drains within a few (timed) seconds. Otherwise, the machine senses too high water level for spin out and shuts down.
Oct 07, 2008 | Kenmore 43142 Front Load Washer
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 80 series washer
you removed the cover ??? cool your looking right at the pump assy remove the 2 clips and release the pump from the motor assy(dont remove the clamps) thers enough room to hold it of to the side, after doin this try starting the machine(it should at least agitate with cover removed.)if it does agitate with no problem stop the machine and reinstall the pump(you may have to manually turn motor shft to correctly align pump. try it again.if it doesnt work now then theres something stuck in the pump(baby sock, bra underwire).
Feb 24, 2008 | Washing Machines
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
