Where do I buy the warm gear from the motor ?
The plastic gear is worn out needing replacement.
    Top Expert:
  • Washing Mach... Master
  • 42,991 Answers
Hi, One of the plastic gears inside the gear
Honestly Dennis - these bad boys are quite vicious and go up like jack-in-the box when you attempt to take them appart - I would recommend you bin it and buy a new one.
Mar 18, 2011 | Tech Solution TS-6000 Shredder
My Craftsman garage door opener is not working - I opened the inside of the opener and motor is humming but gears are like jammed....when I prod the gears with a screw driver they do spin for about 3...
I had the same problem. In my case the bushing for the main drive gear was worn out. This is just below the sprocket that connects to the chain.
What you should do is remove the chain and see if that sprocket shaft is loose in the bushing. The motor should turn without the chain on.
If this is the case check the plastic gears within the case. If there all chewed up and the bushing is shot you most likely need to replace the unit. If the gear's are still good you can replace the bushing.
I'm not sure how much Sears would charge to rebuild it but it is very possible it would be cheeper then buying a new one
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
How to replace power window motor for 2003 dodge
That's unusual for a window motor to go bad, however the plastic track breaks causing the window to become inoperative. If you hear the window motor working, then the plastic geared strip is probably broken. It would be cost effective to you to first find out whether the plastic track is broken for now Chrysler sells a "generic" window track where you cut the plastic track to fit Your Vehicle. Should this be the case, then remove the door panel (a Haynes Manual would come in handy), and take out one pin in the plastic track, while supporting the Window! (smile) and remove the old track and re-install the new track.
A little secret here...buy some Mopar Speedometer Grease while buying the Window Track and grease the metal rail that the plastic track rides on. The Speedometer grease is NOT temperature sensitive, so it works well in Summer & Winter Temperatures.
Should it truly be your Window Motor, Chrysler sells a re-build kit for the Window Motor which has the gears and grease needed to replace the worn out ones in the head of the Window Motor rather than paying for a "Brand New" window motor. All of this (the plastic window track AND the Window Motor Kit), will be under $100.
I hope this helps you,
Let me know if this resolves your problem.
"00 Buck"
"Still living on the Right Side of Dirt..."
Jun 04, 2010 | 2005 Dodge Grand Caravan
Headlamps are stuck in the up position. There is clattering, like a motor gear slipping, whenever lights are turned on or off
Hello, my name is Ben. You may know this is a very common problem in Corvettes. Chevrolet uses plastic gears in the headlight motors and the gears fail over time. You headlight motors are going to need to be rebuilt. There is a company that makes a brass gear to replace the plastic gear. I'm not sure if you are wanting to do the work yourself or having it done. If you are mechanical and feel you can accomplish the repair, I can send you the procedure.
Feb 26, 2010 | 1993 Chevrolet Corvette
Shredder motor runs but gears are not engaging and will not take up paper to be shredded. Model is Royal VF1012mx
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Jun 30, 2009 | Royal VF1012mx Shredder
Chamberlain Liftmaster 1246R won't open/close
if youcan hear the motor turning when you hit the remote or wall button the plastic gear in the oprator has been ripped and if you take the cover off you will see all of the whote plastic dust that has come from the gear being shreded. You can replace this gear. you do not have to buy a new operator. it is very easy to replace this gear. I can't tell you were to buy one because I buy all my stuff from a dealer.
Jun 09, 2009 | liftmaster Chamberlain Garage Door Opener...
Wayne dalton garage door is humming but wont open
Likely the plastic gears are worn out. Unplug the unit from power source, remove the cover, look at the gears. If worn, it will be obvious from the shavings from the gears. You can buy the gear kit on EBAY for a little as $20 depending on the manufacturer and model. Before removing the chain drive, lock a pair of vice grips on the chain and metal chain rail to keep the chain from turning from its current position. The gears can be replaced without removing the opener. Even if you have to remove the opener, it is a simple task. Most have four bolts that need to be removed and it will be in you hands.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Ts 4500 blades not moving
From the sound from your description, it is Probably a cracked gear or a worn bushing.
To get a better idea, you would have to take it apart to see what is going on inside.
Good luck
Feb 06, 2008 | Tech Solution TS-4500 Shredder
Worn Gears
Kitchen ... Betty Crocker Store where you can find Cookware, Small Appliances, Cutlery, Kitchen Tools, Bakeware, Tableware, Barware, Storage products and more.
www.bettycrockerstore.com/
Hi, yuo may ask for the answer of parts needed.
Jan 08, 2008 | Betty Crocker BCF1350 Work Top Blender
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
