Question about ACDelco 2005 GMC Yukon XL 2500 Instrument Panel Connector
I am looking for GMC yukon daneli 2005 stereo/radio steering wheel control harness to use with aftermarket radios with a wired remote control Interface BOSE & ONSTAR
    Master:
  • 442 Answers
This might be what you're looking for:
http://www.amazon.com/ASWC-1-Universal-Steering-Control-Interface/dp/B00B4PJC9K/ref=pd_sim_e_2?ie=UTF8&refRID=15A8XKA3FW70XA0YEDXE
Posted on Apr 13, 2015
  • Alex
    Alex Apr 13, 2015
    Thank you friend
How do i go about finding the radio fuses in my 2005 gmc yukon?
Go to Wal mart or car stereo store and buy wiring harness to plug into existing unit. Makes life simple and comes with instructions.
Feb 23, 2015 | 2005 GMC Yukon
What wire runs steering wheel controls on a 2500 gmc sierra
This is not a question for JVC but more for GMC. On the JVC radio side, if it can be controlled via steering wheel, you will see a blue with yellow stripe cable that states [STEERING WHEEL]. Not all radios can adapt to steering wheels controls.
Aug 02, 2014 | JVC AM FM CD DET FACE CAR STEREO
Steering wheel radio wires, i need a wire color diagram to steering wheel for the aftermarket radio i need to know the wire colors that controls what.
The wires that control the radio from the steering go to the Body Control Module (BCM), not directly to the radio. The BCM sends data over the serial bus to the radio.
Sep 18, 2011 | 2002 GMC Envoy
Can you put a newer radio in a 2001 yukon
Hi, my research indicates you can install a single din aftermarket head unit in the 2001 Yukon.
A couple of good websites to use are crutchfield and modifiedlife.
Crutchfields will identify exactly what adapters are needed, and modified life has the factory wire colors.
You will need an adapter to fill the space between the aftermarket stereo and the hole left by removing the factory head unit.
You will also need an antenna plug adapter.
I recommend you buy the wire harness pigtail to simplify the installation--this may or may not include the antenna plug adapter.
If you have onstar, you will need an additional adapter.
If you have steering wheel controls, you will need another adapter to keep those.
Keep the above things in mind when selecting a new aftermarket stereo, as you will need one that is compatible with steering wheel controls and onstar, if you have either of those and want them to continue to work with the new stereo.
Crutchfield has an link called "outfit my car" that takes you through a "Turbo tax" style questionaire and tells you what will work and what you will need. here is the link: http://www.crutchfield.com/App/Car/outfitmycar/MyCar.aspx
Assuming you have a base Yukon, here are your factory wire colors from modifiedlife.com:
2001 GMC Yukon Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Please let me know if you have questions, and thanks for using FixYa.
Jan 18, 2011 | 2001 GMC Yukon
Have 2003 monte carlo aux input cutting out
If the radio itself works all the time then you probably have a bad connection between the aux device and the radio. It could be a cable, or it could be the jack. Depending on that it is in easy fix or a harder one. You can take it to a place that installs car stereo equipment and have them look at it or just tackle it yourself. If you put in an aftermarket radio you will need a wiring harness and possibly an antenna adapter. Sometimes you need other things that interface between the car and the harness as well such as controls for steering wheel remotes and other special items.
Jul 27, 2009 | Car Audio & Video
Need color codes for radio in 2002 gmc yukon denali
2002 GMC Yukon Car Stereo Wiring Guide
May 23, 2009 | 2002 GMC Yukon Denali
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
Trying to install an aftermarket stereo 1994 GMC 1500
You have to unplug the old radio. The radio isn't the part in the dash. That is just the control to the radio. The radio is actually under the dash above the accelerator pedal. It should have the power wires, speaker wires and antenna wire going to it.
Mar 30, 2009 | 1993 GMC Sierra
2005 Toyota Camry JBL Radio Replacement: Info button issue
Crutchfield sells an aftermarket kit that allows the steering wheel controls to work, but it's $74, and you head unit must be remote control capable. They also sell a wiring harness that works with Kenwood/Toyota as long as you have the original wiring harness that came with the Kenwoood. You'll need to do some snipping and krimping however.
Mar 22, 2009 | Car Audio & Video
What are the two plugs on the back of the factory radio
Power for memory, power when key on or accesories,etc, then all the speaker wires. Have you stopped at a stereo sales place, or autoparts place and asked for an adapter harness to go from your vehicle to an aftermarket stereo? It will make it much easier, much cleaner in case of removal later & will probably save a big headache too.
Mar 14, 2009 | 2005 Toyota Camry Solara
ACDelco 2005 GMC Yukon XL 2500 Instrument Panel Connector Logo
1,178 people viewed this question
Top ACDelco Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you an ACDelco Wine and Spirit Expert? Answer questions, earn points and help others
