Question about Refrigerators
Why does the timer stop on 2 minutes and not restart again for 5 minutes
5 Suggested Answers
  • 400 Answers
SOURCE: LG Split Ac LSA5NF5VFC1 Compressor Stops after every 7 minutes.
One possibility is that it is short of refrigerant and is short cycling due to the low pressure cut out switch? Hope this helps.
Posted on Aug 20, 2009
SOURCE: Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Posted on Sep 22, 2009
  • 454 Answers
SOURCE: coffee maker overflows
contact Bunn directly for help.
http://www.bunnomatic.com/retail/service/contact.html
Posted on Jan 20, 2010
johnjohn2
  • 5763 Answers
SOURCE: mazda 1990 323 1.8L LX, 5 minutes after the
Start by having the charging system checked,unless the car engine spins but doesnt start,if it spins over and wont start then it not the charging system,when the car dies check for spark, remove a sparkplug wire insert a screwdriver in boot and place 1/4 inch near metal and crank engine and see if theres spark,this will help pin point your problem if theres spark then the next thing to do would be to spray starting fluid in throttlebody and see if it starts,hope this helps let me know the results.
Posted on Jun 09, 2010
Testimonial: "Thank YOu for your info,,,Great help, The ingine has a Crank but not a spark retested all parts and found out the problem was in the Distributor the Module not worked, this part replaced whit a used one (150$)used Mazda Parts, and Now running fin, (Odometer 263.000 Km)"
My stereo has CHECK CD on visual display. Not cd issue. What could be causing this?
You can reset the unit by disconnecting the car battery for 5 minutes and reconnecting.
Apr 18, 2016 | Cars & Trucks
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
Ge dbxr463gd1ww stops before cycle ends
Sounds like a safety or limit switch cutting it out, if you wait 2 minutes and it restarts then repeats.
Aug 27, 2013 | GE Dryers
Fridge not cooling but freezer is maytag model mtb1553ar
Your MTB1553ARA Refrigerator sounds to me like it is not defrosting properly. Look inside the freezer along the back wall and see if a layer of snow is building from top to bottom. To test if defrost will work open the fresh food compartment and look for a small opening were you can turn the defrost timer slowly clockwise until compressor and fans stop running. Click here=> MTB1553ARA Fresh Food Section Control Panel and in that photo you will see the=> 68233-2 Defrost Timer that has a dial in the center I need you to turn clockwise. After the compressor and fans stop I want you to allow the refrigerator to remain off as it is for 30 minutes. The freezer should now be defrosting and if after thirty minutes the refrigerator does not restart on its own then again turn the timer again slowly until it does restart. If you need to restart the fridge this way then the problem is the 68233-2 Defrost Timer Next I will detail how to install the 61001946 Defrost Heater and the=> 61005254 Defrost Thermostat
if the defrost timer is not the reason for this happening. Here is a MTB1553ARA Parts Manual PDF Let me know here how the defrost timer test goes, Thanks Sea Breeze
Jun 21, 2012 | Maytag Refrigerators
Dryer will heat and spin. After a few minutes it stops. Try to push to start button and nothing happens. I wait about 20 minutes and it will start again. What is the problem ?
Mine was doing the same. I got a bit of a rattle noise in the timer when I'd try to restart it though. First I unplugged the dryer, I took the control head off, then I took the timer out, and opened it up. Found that 2 of the copper contacts were covered in black soot and had a little corrosion on them. I took some fine grit sandpaper and sanded the contact only till they were smooth and clean. I only did this a short while ago but seems to be working so far. It hasn't prematurely shut off and the timer is turning again.
Aug 26, 2010 | Kenmore 62602 Electric Dryer
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Aug 19, 2009 | LG Heating & Cooling
Main oven failure
Shut off power at the mains breakers and restart. This may reset the unit.
Dec 10, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Tag Timer Resets to Wrong Time
Unscrew the crown and press the lower button, this should advance the minute counting hand one press ata time. Pull ot the crown a further stop to advance the seconds hand and again to advance the tenths counter.
Nov 04, 2007 | Tag Heuer Watches
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
