Question about HP Office Equipment & Supplies
Hp photsmart 8250 system failed error code Oxc19a0013
    Sergeant:
  • 166 Answers
According to the HP website, this error code means the ink system has failed, and the unit will need to be serviced by an authorized HP repair technician - An Ink System Failure or 0x Error Message Displays on the HP Printer...
However, you can try resetting the printer first -
Reset the product
  1. Without turning off the printer, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the printer, and then try printing again
  10. If the reset fails it will require a service.
  11. NOTE: if you are using refilled or remanufactured cartridges try the reset with genuine hp cartridges as they will be recognized as original authentic HP cartridges by the printer
Posted on Apr 13, 2015
SOURCE: HP Photosmart 8250 Support Menu?
I have the same issue with the printer but I do have a solution for you.
I do know how to reset the error codes.
Start by turning off the printer and unplugging the power cord.
Next, you need to hold the Instant Share and Photo Tray buttons simultaneously while plugging in the power cord. If done correctly you will see the LCD Screen turn green with the numbers '1 2 3 4 5'.
After that is done, you need to unplug the printer, and replug it.
I myself have not been able to resolve the issue as to why it is giving me the error code. Any help would be appreciated.
Posted on Dec 03, 2008
bandana_gyrl
  • 181 Answers
SOURCE: HP ERROR CODE 0XC18A0401
There is one fix for the 0x errors and it doesn't always work but this is the only option.
Press and hold the "*" key. Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release in sequence the "1", "2" and "3" buttons.
Display should say "Support" and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says "System Configuration Menu".
Press and release the "OK" button.
Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Jan 29, 2009
SOURCE: hp photosmart error code 0xc05d2381. does this
french oeioe
Posted on Aug 16, 2009
SOURCE: New HP photsmart C7180 All-In-One
I have a problem with HP D7163, the printer's error is ink system has failed, error 0xc18a0206, would you please help me?
Posted on Sep 05, 2009
aschauhan11
  • 58 Answers
SOURCE: ink failure system error
1. Turn the printer off for few minutes then turn it back on
2. Clean ink cartridge
3. Update drivers
4. If nothing works, repace the battery
Posted on Sep 07, 2009
I have a HP Photsmart 8250 it is telling me that the printer cartridge cradle is stuck. I have taken all cartridgese out and in again. I have opened the back and there doesn't seem to be a paper jam. I...
on the printer if the cradle is stuck on right position disconnect the plug from the outlet then push gently the cradle to the left then plug the unit turn on if it is stuck on left disconnect the plug from the outlet then push gently the cradle to the right, hope it helps god bless
Jul 31, 2011 | HP Photosmart 8250 InkJet Printer
I have a system failed error code Oxc19a0013
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord
Jul 10, 2010 | HP Photosmart 3310 Printer
Dell Dimension 8250 won't boot-up IDE fail code 5
install your OS and then firstly run chkdsk..
Jan 21, 2009 | Dell Dimension 8250 PC Desktop
The ink system has failed and can no longer print. refer to printer documentation. error 0xc18a050a on a 8250hp I have a hp 8250 and I keep getting the error message 0xc18a050a. I tried reseting the...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP - HP Photosmart 8250 printer
Ink system failure
it could be a viros or a printer jam
Aug 16, 2008 | HP - HP Photosmart 8250 printer
Error message #Oxc19a0013----Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 8250 Ink System Failure,error code Oxc18a0007. I've tried HP site for solutions with no success. Also tried re-installing software,replacing ink (all genuine HP) but no luck!
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Jun 17, 2008 | HP - HP Photosmart 8250 printer
Photoprinter 8250 error oxc18aoloa
I had the ink system failure on my HP Photosmart 8250. Here is how I fixed it...no promises that this is the problem with all of these failures:
Start by opening the printer up to expose the ink pump on the left hand side. Remove the left side dark grey trim, then take out the screws to remove the left side panel. You will have to use some force. I slightly damaged the plastic because I was impatient - be careful if you want it to still look nice.
The ink pump is in the bottom left. In my printer, a large gear had fallen off of the pump and was laying in the bottom of the case. I removed the belt drive to the ink pump, then removed the large pulley that the belt went around. This lets you put the gear back on the ink pump. Use a dot of glue on the shaft if you want. Now, replace the large pulley and the belt.
This fixes the problem, but does not clear the error code. To do this, go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=us&dlc=en&lang=en&cc=us Click on the link for your operating system, then click on, download, and use the link that says "recomend update to fix long power-on cycle and ink system failures" This clears the ink failure trouble code and lets the printer re-initialize the ink system.
Oh...put the plastic back on if you want to. Otherwise, you can leave it off and watch all the bits and pieces move around in the printer.
Again - this is how I fixed mine. No promises that this is what has caused the others to fail. The HP website says not to use the patch if you can see ink coming out of the printer. This sounds like good advice to me as the initialization process runs the ink pump for about a minute.
Mar 05, 2008 | HP Photosmart 8250 InkJet Printer
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
