Question about Zanussi Washing Machines
Model no.zwf1432 w
I have purchased replacement bearings for above washer,I have removed drum from machine but it seems the drum doesn't come apart as no bolts just looks as if it's been heat sealed anyone have any information yet please
  • Zanussi Master
  • 2,963 Answers
If you don't have it, try this on line http://laundry.manualsonline.com/manuals/mfg/zanussi/zwf_1432_w.html?p=1
Posted on Apr 13, 2015
  • Anonymous Apr 14, 2015
    not the help I needed,I have a user manual,needed advice on unit disassembley
  • gbob59 Apr 15, 2015
    there is a chance one of the appliance parts online stores can help you. They know their parts!
THERE'S A FUNNY NOISE COMING FROM THE BACK AND LOCATED AT THE DRUM NEAR TO WHAT SEEMS TO BE A GENERATOR (BY THE MAGNETS AND COILS INSIDE). KIND OF PLANE TURBINE SOUND. NEED TO KNOW HOW TO BRAKE IT APPART...
Your problem is a bearing of inner tub may also need spider assembly caused by overloading using non HE detergent 0r to much soap if noise gets worst it will take out seal and will start leaking thru-back side under stater motor that you call generator
Remove stater drum by holding inner drum and taking rear nut of stater drum after removing drum UN plug wire connections remove 4 bolts holding coil . then remove front of washer remove all counter waits remove all bolts from outer tub remove shocks remove springs and drain and vent hoses pull out the whole basket from unit pull tub in half remove inner tube Pop out both bearings back and front replace with new bearing and seal reverse back together same way you take apart may take 2 people heavy stuff
Oct 25, 2013 | LG WD-15517RD Front Loading Steam...
My washer is off track the drum moves all around in the spin cycle
(a) Open wide the front loading door. Ensure the drum is totally empty
(b) Remove the top of the washing machine and check that the Damper springs either side of the drum are attached and not broken or loose. Push down on the top of the drum to ensure they are both in good working order!. If they are broken, replace them.
(c) put both hands inside, and hold the top of the drum and try to lift the drum in a 'up and downwards' motion.
(d) If there is any movement in the drum this means the drum bearings have worn or disintigrated and need replacing.
(e) Remove the back panel from the washing machine and you will see a large wheel affixed to the drum. The bearings are behind it.
(f) Should you wish to replace the bearings or springs yourself to save money, they can be purchased at trade price from espares tel: 0844 375 3375
by giving them the make and model number of your washing machine. They also sell at a very reasonable price 'How to' video's so thast you can do it yourself and save pounds.
May 18, 2012 | Washing Machines
Noisy bearing while spinning
The seal in the drum has failed allowing water to leak into the bearings causing them to rust. Once the bearings are no longer round, the bearing noise will get louder. To replace, the washer needs to be taken apart and the drum needs to be removed in order to replace the bearings. Can be a difficult and expensive repair. Get a few estimates before deciding whether it is worth reparing. Sorry.
Oct 04, 2010 | Maytag Neptune Washer
Our front loading Kenmore MODEL 41742042100.has begun sounding like a jet enjine when it is spinning,someone told me that it is probably bad bearings, is it worth having this 7yr old machine repaired or...
Hi.
I
f you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Kenmore 44042 Front Load Washer
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum Bearing Replacement
With a plastic tub (outer drum as you describe it) removal of the old bearings can deform or bruise out the plastic housing a little - you will need to check that the new bearings will be really good fit. You may need to use a retaining compound if not, to ensure that the outer journals of the bearings don't creeping round in the plastic housing and wear it looser.
I did my Hoover Electron 800 bearings (metal tub). As i recall it was fairly straightforward - needed a gasket for the tub backplate on that.
Unbolted tub backplate from tub and withdrew it through rear of chassis along with drum/drum-shaft/bearings assembly, removed pulley, tapped shaft through bearings with softfaced mallet (or hammer & wood), drifted bearings out gently, working evenly around circumference.
For plastic tub some kind of suitable extractor may reduce chances of deforming bearing housing during bearing removal, compared to drifting them out. If it'd serve to ease the new ones in too then that'd be even better.
Don't forget to check/clean the water level pressure sensor path while you're at it - stave off any problems in that area for a while while you have the machine apart. ;o)
Dec 29, 2007 | Hoover AL130 Front Load Washer
Drum wont turn
Sounds to me like the rear bearing is seized up. Seeing how you describe its been noisy for ages I would say the porblem is the bearing. Its not a easy jub to replace for a novice.The entire tub must be removed and taken apart to replace the rear bearing. To take the case apart its only the front panel with the door that that will come off. there should be a wire with a spring that holds the bellows to the door. remove that and the rest should come apart from the inside. Dont forget to disconect the dor switch.
Aug 05, 2007 | Hotpoint WMA31 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
