Question about Lexmark T430 Laser Printer
It says load MP feeder A4 - Lexmark T430 Laser Printer
    Sergeant:
  • 166 Answers
It means "put paper in me"
A4 is standard 8.5 x 11 paper, available anywhere paper is sold.
Posted on Apr 13, 2015
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
Printer asking me to Load MP Feeder with A4 - the
factory reset should fix it unless the paper size ciruit board and levers have been physically damaged (back left on the printer in paper tray slot)
Feb 01, 2010 | Office Equipment & Supplies
Load mp feeder with a4
find the switch and turn it to auto paper in the printer settings, mp is for manual paper feed ap is probally for auto paper feed, its a guess . hope it helps
Dec 01, 2009 | Lexmark Office Equipment & Supplies
I keep getting a Load MP Feeder Letter message. I can't clear what to do?
MP Feeder refers to Multi Purpose Feeder or Manual Paper Feeder or just plain bypass feeder. There should be a door that folds down to gain access to your MP Feeder tray. Try loading letter size paper on this tray.
Nov 24, 2009 | IBM Infoprint 1332 Laser Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Load MP Feeder
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
Nov 20, 2008 | Lexmark Optra M412 Laser Printer
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Sounds obvious
Your printer is set to load from MP feeder, either you load the A4 in the MP feeder or change from the paper menu which tray you want the printer to print from .
Regards
Ashraf
Apr 03, 2008 | Lexmark T640 Laser Printer
Manual Feed Issue
will not pick up envelopes to print
Feb 09, 2008 | Lexmark C530dn Laser Printer
Lexmark T430 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
