Question about Fossil Watches
Battery replacement for fossil watch fs4358 - Fossil Watches
  • 14 Answers
SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Posted on Dec 05, 2007
SOURCE: Fossil ES1592
watch press
Posted on Jun 19, 2008
escapement
  • 2334 Answers
SOURCE: Need manual and battery info for Fossil S+ARCK PH-1002 watch
Of course, you can.
Open the watch and take the battery out. Memorize all the writings on battery and buy exactly the same one. You need to memorize wich way up the battery is originally fitted. If you will insert the new battery the other side up, you can damage your watch movement.
Rate me, please.
Posted on Mar 21, 2009
SOURCE: Fossil Watch Repair,crystal replacement Fossil TM7221
See SuisseWatchService.com for watch crystal replacement in the USA.
Posted on Oct 22, 2009
escapement
  • 2334 Answers
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Posted on Feb 28, 2010
What battery does the fossil ch2599 watch take
You are going to have to remove the battery to find out which one you need. For instructions on how to do this see: http://www.mademan.com/mm/fossil-watch-battery-replacement-guide.html. You can buy the battery at: http://shop.batterymart.com/search#w=fossil%20ch2599%20watch%20battery. Replacing a Fossil battery is delicate and tricky. Fossil recommends that you send it to a shop that specializes in Fossil watch battery replacements.
Feb 25, 2015 | Fossil Watches
What is the battery number for a fossil am3848
We can tell you the battery number you may need for your Fossil Watch, but it is not worth you to change it yourself.
Many people think that replacing a battery to a watch is an easy task, but that is far from truth.
Note that once a watch is opened ( if you can get it without leaving marks all around the case) all circuits are extremely delicate. If you may touch some part with any metal instrument or even with your fingers, you will loose your watch.
Best you can do is take it to be replaced to a watch shop, sure you have one near you.
But let me insist, if you need the battery number, let us know and we will provide.
TicTacArea.com is Fossil authorized dealer, you can find our complete Fossil watches and Straps for Fossil watches here:
Apr 04, 2014 | Fossil AM3848 Watch for Men
Second hand and battery replacement on fossil watch
Fossil watches have an 11 year warranty. Any jeweler can replace the battery. If that doesn't solve the problem and you registered the watch or still have the receipt call 1-800-TICTOC1 for repair.
Sep 24, 2011 | Fossil AM3424 Wrist Watch
Looking for battery for Fossil Watch Style # FS4317 Watch for Men
Link
Hi mm01891,
Please browse above link for your fossil battery replacement. Kindly refer this matter to your authorized Fossil dealers.
Thank you
May 24, 2010 | Fossil Watch Style # FS4317 Watch for Men
Basic Functions of Fossil FS4358
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all FOSSIL watch manuals.Rate me, please.
Mar 17, 2010 | Watches
My Fossil watch worked when I took it off, it just needed a new battery. Now, I tried to replace the battery, and it won't work
Check that the battery is in the correct way up.
Try cleaning the battery with surgical spirit.
If these steps fail, take it to a watch shop.
If this also fails, find you nearest Fossil dealer (Fossil/customer care - store locator
Feb 11, 2010 | Fossil AM3784 Wrist Watch
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Watches Logo
172 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
