Cant change print font for printing on disk
I have changed font before but now I cant manage to make any change
    Top Expert:
  • 6,702 Answers
You don't need other ink, you need special disks. The printable disks can be printed with normal ink.
Posted on Apr 13, 2015
How do I increase the font size on my hp printer when printing from my computer
The font size is usually controlled by the properties of the page you are trying to print. Try increasing the size of the font on the file.
Feb 17, 2015 | HP Office Equipment & Supplies
How to change the color for printing order (In the Kitchen printer)?
Are you using Microsoft Word? If so, you just need to change the font colour, by clicking on 'Font' and clicking the desired colour.
Jul 03, 2012 | Casio QT 6000 Point of Sale Terminal
Internet print is really small how do I enlarge
Hi, you cant enlarge the font for the internet directly to the printer, Alternative option copy and paste the file or pictures to word format so that you can change the size of the font and resize the pictures. thanks.,
Apr 24, 2011 | Computers & Internet
I have a photosmart 4650...when I print from a web page, the print is so small I cant read it. How do I change the font size?
Best Answer -
That entirely depends on what you are printing. A printerwill only produce what it is given.
If you are printing your own document then you change the font in the documentbefore printing or select the font before you start.
However I suspect the reason you are asking this is because you are printing apdf document from the internet. In which case the font is fixed.
If so, then you will have to copy and paste the document in to a word processorlike Word, highlight it all and the increase the font. You will then have toreformat the whole document as the increased font will throw the orginalformatting all out of line.
When you have straightened it all up then print it off.
ALTERNATIVELY, if you are printing on ordinary web page then you need to follow the below instruction
Instructions
1. 1 Go to theweb page that you want to print and right-click it. Click "PrintPreview." If you want to print part of the page, highlight the contentthat you want to print and right-click the selection. Click "PrintPreview." 2. 2 Click the "Page Setup" icon located onthe top of the Print Preview window to launch the Page Setup dialog box. Click"Change Font." 3. 3 Select the font you want to use in the"Size" window. If you want to change the font type, make yourselection in the "Font" window. Click "OK" to save thechanges and click "OK" again. 4. 4 Turn on your printer if it is not on. Click the"Print" icon on the Print Preview window to print your web page.
Sep 29, 2010 | HP Office Equipment & Supplies
Cannot scan to my PC
If you are using a usb connection and can print and have button manager installed then go to control panel to scanners and try to have windows find a scanner. Your driver disk must be in the computer. you have to install the sharp scanner drivers from the disk for it to work. Button manager will let you decide how to use the scanner.
Nov 19, 2009 | Sharp AR-M205 Copier
Cant make prints lighter or darker
There are two ways to do this. One is to change settings in whatever application your are using. Increase your font size or bold your font (if you're talking about a document.)
The other way is to change your printer properties. Go to your printing preferences (from your print dialog or from Start->Printers and Faxes->right click on Lexmark 5400 Series->select Printing Preferences) and increase your Print Quality.
Steve
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Need to make the font larger and more readable
you use ESCPOS commands to enlarge font size, to double the size of the printed font use <2D>!<22> at the start of the print job. the 22 is the XY zoom factor so <36> would be 3 x wide and 6 x high hope this helps
Nov 25, 2008 | Epson TM-U220 Matrix Printer
Labeler #1950
Press "Line Out" to remove return character, It thinks you want to print on more than one line so is making font smaller to fit. Good luck.
Jan 21, 2008 | Brother P-Touch 1180 Label Printer
Printer font default
OKI printers tend to only print in the font size that you give it in the print options or the softwares printing properties that you are using, you will find that it just indicates the font size being printed if it changes back, this means it's set to 10 in the print properties or the actual programme print setting.
Aug 03, 2007 | OKI MICROLINE® ML390 Matrix Printer
Brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Aug 02, 2007 | Brother HL-2040 Laser Printer
jasbo
jasbo
