Picture keeps freezing on bbc HD channels have to switch off then on again but after a bit more veiwing freezies again
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
Check the input signal strength. If this is so weak, this kind of fault can occur.
Posted on Apr 13, 2015
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
dave1645
  • 834 Answers
SOURCE: I have retuned my Panasonic HD TV as per your
both of those channels are in anolog, so on todays tvs they are going to look that way, sorry , something you have to live with if the cable company puts them on a digital channel they will look better but not HD quality
Posted on Sep 30, 2009
tvservice306
  • 458 Answers
SOURCE: picture quality poor on certain channels
if all channels poor quality TV problem
if just one or tow channels bad quality not tv problem....
Posted on Oct 28, 2009
  • 4 Answers
SOURCE: switching between a 720 hd channel and a 1080 hd
The unit has an auto detection circuit to determine what signal is being input, it then processes it, however if the signal is altered (different channel) the TV will at times try to process it through the wrong resolution circuit causing problems. Change the input of the TV and then change it back and it will redetect the 720p instead of the 1080i and display it properly. Check with Sony for possible updates.
Crampy
Posted on Dec 11, 2009
  • 36 Answers
SOURCE: When we change channels the picture freezes and we
are u sure your arial connections are ok?
Posted on Feb 15, 2010
Screen freezes BBC Channels only. Unfreeze by switching off TV. Handset and TVs buttons fail to work. Minutes laterscreen freezes again. No problem with non BBC channels
turning tv off and on wont make it better
you on roof antenna or a cable tv
if antenna only
you may be in weak signal area
or a new construction site or buildings deflecting the signal
antenna problem or needs upgrade
go back to TV set up and re-tune tv to bbc if possible
if it freezes then you know its an interrupted signal
Mar 26, 2017 | Televison & Video
Why does my bush freeview box freezes on bbc channels why
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 06, 2014 | Televison & Video
Can anyone tell me why all of my BBC digital channels have no signal at night or the early morning, but work again during the day!? thanks
Check the signal strength. If the signal strength is weak, this can happen to digital channels. For analogue channels, the fault due to weak signal will be a grainy picture.
Jul 26, 2014 | Goodmans GTVL32W27HDF 32 in. LCD TV
Shall I buy signal booster? signal 23 bit error 3 but only BBC channels affected. Picture keeps breaking up
how old is your aerial and cables. and were is your aerial located loft or wall etc. in loft would buy one if roof may be a bent out aerial or heated cable from the sun. if you have been fine with the signal from the 28th of june till now would say arial problem or cable.
Oct 02, 2013 | Televison & Video
Had the tc 8 months just turned it on and the screen and volume keeps breaking up and freezing
try to reset the systemand upgrading to the latest update that is wat i had done all good now..
Mar 31, 2012 | Audio Players & Recorders
P2370HDBL Samsung TV- BBC 1 and 2 picture freezes
While it is under guarantee, don't even think about it.....take it straight back for repair...
Jan 16, 2010 | Televison & Video
Unable to get BBC 1 and 2 on Digital. Both Channels are ok on Analogue but switch to Digital and programmes start at ITV( channel3) Have re tuned since last digital update but still the same. Have used the...
There is not a problem with the TV despite it's age this is can be due to your reception of the digital package for BBC. Have you checked through he full listings? sometimes the BBC channel will be at a different number setting because of the transmitter you are receiving. I assume you are using a digital box, you can enter a menu which will give you an indication of the strength & quality of the incoming signal. Do you pick up some of the other BBC channels such as BBC3 or CBBC? It's possible your aerial strength is a bit weak for the digital BBC package & you may need to have that looked at.
Oct 07, 2009 | Panasonic Televison & Video
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
My Tv a Sony Brava KDL 32 D300 Has a problem while on any BBC program picture freezes every 3 minutes TV switches of and back on for an other 3 minutes and dose the same again, This only happens on the BBC...
If it works fine with other channels the issue is with the BBC channel. Maybe they will work sometime in future - don't lose any sleep over it - your set is fine.
Aug 22, 2017 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
