Monitor dont turn on
All elements on board are ok. but out put voltage for 5v is 3.9v and for 12v is about 14 volt.
  • edris
    edris Apr 15, 2015
    thanks for your guidence. but i replaced supply board with new one the monitor work properly.it can't be from pannel i guess. what you think?
    Master:
  • 301 Answers
Depending on the monitor, it may not be worth fixing, a power supply card or the video card is going to run you about $20-30 to get a new one and a price a old monitor that work is about the same with shipping.
How To Troubleshoot Problems My Monitor Died
Posted on Apr 28, 2015
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
If your 5V line is that low, you either have a shorted capacitor or your backlight has failed and it shorting the HV supplying it.
I suggest looking at your back light at its ends to see if you see them as blackened.. this means the ignition coil in there has opened to make a spark (what makes it black). The 14V is probably OK. there is some fudge room on the 12 because it mainly drives peripheral items to the data (5v line).
Posted on Apr 13, 2015
Testimonial: "thanks for your guidence. but i replaced supply board with new one the monitor work properly.it can't be from pannel i guess. what you think?"
  • edris
    edris Apr 15, 2015
  • Stan Skaggs
    Stan Skaggs Apr 27, 2015
    I would still look at the bulbs in the panel.. something made the power supply die. You need to be sure the dead bulb did not drive the power supply to ruin. Just for sure look at it..
RCA L32HD31 Only about 1" of screen shows picture
Thank you for using Fixya. I am glad you have performed most of the testing for me :) Anyways the problem is definitely related to the T-Con also known as LCD controller or Timing CONtrol board. Replacing the same should resolve the problem. If you can get me the part number off the board, I can find you a replacement.
Dec 29, 2011 | RCA Televison & Video
Start up light flashes once and it won't power on
Most probable cause is the power supply. Look at the back of the computer, check the voltage settings located near the power cord. This will be the small red tab indicating two different settings, If your in the US it should be set to 115. Also, the power supply should run the internal fan when it is turned on.
To test the power supply try this:
Open your computer case and locate the gray box that is the power supply unit. Trace the wires from the power supply to the boards and devices and disconnect all the cables by unplugging them.
Find the big connector plugged on the the motherboard, make sure it is disconnected and short the two pins: (GREEN & BLACK) Short green pin (14) to GND (any black) to switch power supply ON, disconnect green from GND to switch OFF.
This will switch the power supply, you should hear or see the fan in the power supply spin. If you do not see the fan spinning, and your sure you have shorted the correct wires, you have a faulty power supply. If you see the fan spinning, you can now test the voltage coming out of the power supply.
Place a volt meter on the following colors to test voltage:
The color code for the wires is: Red = +5V, Black = Ground (0V), White = -5V, Yellow = +12V, Blue = -12V, Orange = +3.3V, Purple = +5V Standby (not used), Gray = power is on (output), and Green = Turn DC on (input).
Feb 12, 2011 | HP Pavilion a6110n PC Desktop
I have this monitor and it became now blank means just white screen i have opened it and first i test the lcd panel on another one its like good then i replaced video mixer ic which named realtek and...
Those voltages does not sound right, it should have 5v for the logic board and 16~20v for the inverter board for this 20" screen size, but you are getting the white screen which means that the backlight is working, so your measurement may be wrong. The white screen means that the T-CON board is not feeding either the 5v or 12v (depend on the screen makes and model) that will be the first palce to check, the logic board supply this voltage through a switched transistor to turn the T-CON board on or off (off during standby mode).
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
I could not locate any free sch for this model yet.
Sep 27, 2010 | Acer X203H bd Monitor
Please how can i identify 5v and 12v terminal on the circuit board?
<P>Is the monitor working/ If it does you can measure the DC voltages on the DC secondary side, the 5vdc will usually use 10~16vdc cap, the 12vdc will use 16~25 vdc caps.</P><P>If you can post the picture of the circuit board then I can tell you where they are at, I will need both sides of the board.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 25, 2010 | Compaq TFT450 14" LCD Monitor
Monitor has power only, no display. Serial #08138JA019415. Product Name LM729.
ok, your monitor problem is the inverter or lamps is not working well. you need do:
1) first thing you need check power board capacitors if there is any swelled it should replace. check all DCoutput voltages like 5V/12V etc. normall
2) check the inverter board it can maks this problem
3) if inverter works normall that is lamps at downside getting old, need to change.
hopeful all thing you can do it well
hope this help you fix it, please rating me thanks
May 14, 2009 | AOC LM729 17" LCD Monitor
Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
MONITOR FAULT
check A/C voltage,fuse,maincap220/450v,bridge rectifire,reg.IC,FET.
check O/P sec. Voltages 5v,12v,65v,80v,150v Voltages may be variations on make.
Combo section 80vdc,60vdc
processor 5v,Vertical sec+12v,-12vdc
filament sup.6.3vA/C
Horizontal sec,H O/p 100v/120v
check dries
and pt
Aug 29, 2008 | Computers & Internet
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
Computers & Internet Logo
295 people viewed this question
David Payne
David Payne
