Question about Ricoh Aficio SP 3510DN - Printer - B/W - duplex - laser - Legal, A4 -
Getting sc542 error code in display
I need steps and solution for this printer.
    Sergeant:
  • 166 Answers
Previously answered by AndyBell Error code sc542
this is an error for the fuser heat up..the temp is not being maintained or fluctuations.
try this -
press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change
enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.
turn machine off..
if the code disappears it could have been just a glitch
if not check the fuser to see if there is heat coming from it
the lamps will come on at the start up.
you can check this by putting a screw driver in the actuator slot to cheat the door switch
if you see the lamp come on then you may just have to clean off the thermistors ..
open the fuser up with the top screws and check that there isn't any build up of toner on thermistors..
hope this helps
Posted on Apr 13, 2015
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
How do I clear SC542 error?
That is a fuser fault code will need to repair fuser first. If you buy the fuser might come with instructions to reset code.
Oct 22, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
What is error code sc542
I found some information on this error at http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
Mar 08, 2011 | Ricoh Aficio 3025 All-In-One Laser Printer
Error code sc542 on ricoh spc222sf?????????????????
Press the red CLEAR/STOP key till you hear the little beep. Press 1 0 7 Press the green COLOR START key. The display changes into MAINTENANCE MODE Use arrow keys to go to ENGINE MAINTENANCE and hit Ok Use the arrow keys and select FUSER SC RESET and hit Ok Hit OK again at the Execute prompt.
Once it is done executing the reset, power the unit off and on.
If the error comes back again, it is likely a real hardware problem and you may need to replace some components.
Sep 30, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Transformer blew at our office yesterday, now calling for a service call, error code SC542???
sc542 is a fuser temperature error code, which could either be something simple (a bad sensor reading) or something serious (a blown thermostat). Either way you'll need to have your service technician come take a look at it and reset the code. (Unfortunately, turning the printer off and back on won't help.)
Sep 14, 2010 | Gestetner C7526dn Laser Printer
Error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
Apr 21, 2009 | Office Equipment & Supplies
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio SP 3510DN - Printer - B/W - duplex - laser - Legal, A4 - Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
