Question about Ricoh Aficio SP 3510DN - Printer - B/W - duplex - laser - Legal, A4 -
Error code sc542, need solution - Ricoh Aficio SP 3510DN - Printer - B/W - duplex - laser - Legal, A4 -
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 245 Answers
My dear you chek heater unit
Posted on Sep 02, 2015
5 Suggested Answers
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
M2Tech1
  • 313 Answers
SOURCE: error code SC542, unable to clear message from
this is an error for the fuser heat up..the temp is not being maintained or fluctuations. try this press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.turn machine off.. if the code disappears it could have been just a glitch if not check the fuser to see if there is heat coming from it the lamps will come on at te start up. you can check this by putting a screw driver in the actuator slot to cheat the door switch if you see the lamp come on then you may just have to clean off the thermistors .. open the fuser up with the top screws and check that there isnt any build up of toner on thermistors..hope this helps good luck A
Posted on Jun 12, 2009
bosegautam11
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
gmeades
  • 166 Answers
SOURCE: how do iremove error of code sc542(ricoh aficio 1515mf)
try this -
turn machine off..
the lamps will come on at the start up.
open the fuser up with the top screws and check that there isn't any build up of toner on thermistors..
Posted on Apr 13, 2015
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
How do I clear SC542 error?
That is a fuser fault code will need to repair fuser first. If you buy the fuser might come with instructions to reset code.
Oct 22, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
Now when i put my photocopy machine on the SC542 code error appears So i need a solution for this problem
Hi rfofie,
There's no specific brand or model you have mentioned on the issue that you needed help. However, I can provide you the meaning of the error code that you are getting. The SC542 error code is a Fuser Temperature Error. That means that the fuser did not warm up fast enough. You will have to replace the fuser to get rid off the error.
Hope it helps.
Thank you for using Fixya.
Mar 29, 2011 | Office Equipment & Supplies
What is error code sc542
I found some information on this error at http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
Mar 08, 2011 | Ricoh Aficio 3025 All-In-One Laser Printer
SC542 error code
Without a model, I can't give you a lot of information, but I am assuming it is a Ricoh machine (Possibly Lanier/Gestetner, same difference), as that's the format of their error codes. An SC542 error code is a Fuser Temperature Error, meaning that the fuser didn't warm up fast enough. It is extremely likely that you will have to replace the fuser unit before the error code will go away. Please give me a model number if you need more information and I will try to be a bit more precise with the information. Thanks.
Feb 28, 2011 | Office Equipment & Supplies
Transformer blew at our office yesterday, now calling for a service call, error code SC542???
sc542 is a fuser temperature error code, which could either be something simple (a bad sensor reading) or something serious (a blown thermostat). Either way you'll need to have your service technician come take a look at it and reset the code. (Unfortunately, turning the printer off and back on won't help.)
Sep 14, 2010 | Gestetner C7526dn Laser Printer
Errore sc542
Error SC542 indicates a fuser temperature problem.
you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Good Luck!
May 07, 2010 | Ricoh Aficio 1085 Laser Printer
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
the reset should be all you need...
reset link
Feb 08, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
Apr 21, 2009 | Office Equipment & Supplies
Ricoh Aficio SP 3510DN - Printer - B/W - duplex - laser - Legal, A4 - Logo
146 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
