TV appears to get AC Power, but can't get anyuthing to work on it.
Nothing seems to work. I tried cold boot (TV unplugged for houjrs; power switch held down for > 10 secs, then ujnplugged and replugged in. power green LED on front comes on, seems to execuute a command by causing the "OPC" green LED to flash on and off, but nothing happens. can't get any channel to come up or to access any source (antenna, TV, input 1 etc.)
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 13, 2015
Compaq presario v6317 not turning on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
May 04, 2012 | Compaq Presario Computers & Internet
Samsung 26" LCD TV
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jul 17, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Insignia tv will not powerup
Nothing at all? Does the screen seem to go from dark black to a lighter shade of black?
If the screen appears to stay on the darker shade of black then it is broken, and needs to be sent for repair. ( ie the screen isnt powering on when the tv is and there is nothing you can do without opening it.
You might try unplugging all cables and leaving it off with no power for a day This is in effect performing a factory reset.
and this may sound stupid and patronizing but is the TV being taken out of standby mode and actually switched on?
Nick
Sep 09, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
Booting problem
You need to do power drain
step1. remove battery and ac adapter from your laptop
step2. HoLD POWER BUTTON for 30secs-1mint
step3. put back battery and ac adapter
step4. power on it sud boot normally
try this hope it helps you
Feb 25, 2009 | Compaq Armada E500 Notebook
Blank Screen
sounds like the mother board is failed..try one more thing..remove battery, run on power supply only, and see if that helps..otherwise, it's motherboard replacement time.
Nov 21, 2008 | Toshiba Satellite A135-S4527 Notebook
I have a Sony trinitron tv model no. KD32DX40U. When trying to turn tv on the red light below the on/off switch continues to flash red twice and green once when trying to switch on. Because of this tv does...
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. if this did not work then check with other power supply unit ....
Good luck..
Aug 01, 2008 | Televison & Video
Will not boot ??
sounds like a problem i had with a philips laptop (which appears to be a twinhead repackaged as a philips)
This might sound weird but it works........
Take the battery out and disconnect from the ac
Press and hold the power button for about 40secs
connect the ac but don't replace the battery and press the power button
then replace the battery and turn it on. it should work
Apr 09, 2008 | Twinhead SlimNote N12PI Notebook PC
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
