Question about ErrorExpert
Canon ir 7086 machine finisher not working not to lift the tray up and down
Canon ir 7086 error e012
DRUM MOTOR OR SOLID WAST IN DRUM UNIT (PROCESSING UNIT)....OR DISCONNECT AND CONNECT ALL DC CONTROLER JACS
Apr 15, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
I have a canon copier with colater the colater when you start the machine goes down and just clicks and never comes back up again. The screen gives me error code E000540-0001
E540
Main Cause: The tray home position sensor (PI8) is faulty. The tray lifter motor clock
sensor 1/2 (PI9/PI19) is faulty. The tray upper limit detecting switch (MS5)
is faulty. The tray lifter motor (M5) is faulty. The finisher controller PCB is
faulty.
0001 The ascent does not end in 15 secs when the tray lift motor is
driven; or, the tray home position cannot be detected when the tray
lift motor has been driven for 15 secs.
Feb 10, 2011 | Canon imageRUNNER 6020 Copier
Canon IR6570 finisher trays are stuck at top. Can you tell me how to get them down?
Often times the alignment of the exit trays will become skewed. To correct this issue and restore a level balance, grab both sides of one of the exit trays, then while pushing down on one side, lift up on the other. This act will work to level the tray and cause the lift motor to re-engage. Sometimes it can take a little bit of muscle to correct it, but don't worry, these finishers are designed to be re calibrated that way.
-David.
Oct 30, 2010 | Canon IMAGERUNNER 6570 Copier
I have this machine Canon IR 7105 B&W
Odds are is that the finishers exit bins got stuck while looking for it's HP. Most of the time it is a garbage can.... Move the object blocking the path of the exit trays first. Then turn the power switch for the finisher off first then turn the main power switch on the right side of the copier. Once it is all off > turn the finisher back ON first then the copier and then remove the paper jams.... Good Luck
Apr 24, 2010 | Office Equipment & Supplies
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
Apr 07, 2010 | Office Equipment & Supplies
CANON IR 7200 TROUBLE CODE E000542-0001
It's related to the finisher tray motion. It's usually caused by something getting in their way when moving down eg box of paper or dustbon.
Move anything that could be interfering with the tray switch off and on and test.
Jun 09, 2009 | Canon imageRUNNER 7200 Copier
Computers & Internet Logo
63 people viewed this question
Top ErrorExpert Computers & Internet Experts
David Payne
David Payne
Are you an ErrorExpert Computer and Internet Expert? Answer questions, earn points and help others
