Question about Gateway MS2285 15.6in Laptop X2 2GHz 4GB 500GB DVDRW
On attempt to boot-up goes into lots of beeping and ask for HDD PASSWORD.........
    Top Expert:
  • Gateway Master
  • 22,812 Answers
Type the hdd password or contact the manufacturer and after proving ownership, they should be able to help.
Posted on Apr 13, 2015
When i turn my d257 acer aspire one on it goes to blue screen asking for a password, or it either goes to a screen that says no boot disk
No Boot disk found - usually indicates the HDD is not located.
so you need to validate the HDD is inserted properly, and locked into the HDD slot. securely,
Blue Screen asking for password, could mean several things,
basically you need with both errors, take to a good Repair Tech and have this looked into... PASSWORD can be either for BIOs or HDD,
or the system went into LOCKED MODE and password is needed to UNLOCK it.
Mar 03, 2015 | Acer Aspire One D257 Netbook
My dell d610 is asking for a hdd password. what would it be there is no password for this computer?
HDD password? Is the laptop encrypted? Unless it s a system password set in the BIOS. You'll have to know what that is or reset it.
Reseting the BIOS requires taking apart the laptop and finding the CMOS battery and shorting it.
Oct 22, 2012 | Dell Latitude D610 Laptop Computer -...
Trying to remove or reset hdd password, cannot get to bios
Hard drive password is difficult to remove. These WEB sites maybe able to help you.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/ .
Sep 10, 2012 | Gateway MX Computers & Internet
Hi, I have a Toshiba Satellite L350D laptop which when booted up asks for a HDD password (which I do not remember setting at any point). As I understand it, the password is stored on the eeprom on the...
HDD passwords are designed to be 100% secure and there is nothing available to reset or remove the HDD password whether the password failure is caused by human error or HDD defect.
Users must ensure they have regular backups.Unfortunately,a new HDD will be required and is not covered by the standard warranty.
Mar 14, 2011 | Toshiba Computers & Internet
Samsung r40 not loading xp
If the computer boots in to safe mode fine, you more than likely have a virus or spyware interfering with the boot process.
Windows also could have corruption on it.
Insert your windows XP CD and boot the computer, you may need to set your boot order in BIOS so tht CD is first.
Once the CD loads Run the recovery console Select 1 for the C: drive if it asks for a password this is generally blank or will be the password on the "Administrator" account you see when you boot to windows in safemode
Once in the recovery console do a chkdsk /f command
This is will check for errors on the disk and can fix a lot of boot issues
I would also suggest typing the command mbrfix to replace the master boot record.
If it still will not boot you may need to reinstall windows xp
Nov 02, 2009 | Computers & Internet
My MSI P6NGM-based system stopped working. On
Parity is a memory ( Ram problem ) try removing 1 Stick. or changing it into another slot. if you suspect Bios. remove power cable. locate The CMOS Battery. remove for 10-15 seconds, And replace it. this will reset the bios to it,s default settings. you,ll know if your asked on boot-up to run setup to change time/date.
Mike @ Compurepair.
Sep 05, 2009 | MSI Computers & Internet
My Laptop ASUS A8Jp ask for a HDD password
Hi
Have you tried Debug ? First run a Debug and that will remove everything from the HDD including the partitions and than do a fresh OS installation
Aug 30, 2009 | ASUS A8Jp Notebook
Cant boot
If you are sure no one has tampered with it and entered a HDD password and it is not prompting for a password then it is most likely a HDD failure. It is possible the BIOS will still recognize the HDD. Try disconnecting and reconnecting the HDD if you can access it there should be screws on the bottom marked with a cylinder symbol.
Jan 24, 2009 | Toshiba Satellite A205-S4617 Notebook
Cant boot
In your bios you should be able to change your settings for the hdd. Make sure everything in bios matches your hdd & then save changes & reboot. Hopefully that will allow you to enter windows.
Jan 24, 2009 | Computers & Internet
Replaced hdd on emachine w3615,light on mobo but it wont come on.
Hi ipackrat21, that little green led you see is telling you the motherboard has standby power. (Its supposed to be green & on).
Make sure the hdd jumper is set to, master without a slave). In a one hdd system.
When you replaced the hdd you also need to enter the bios menu.
In the bios you'll need to make some changes. First you should see the new hdd listed in the bios. (Normally it list the hdd by model). If your hdd is shown than go to the title "BOOT". You need to set the boot order. A normal boot order would list like so;
First boot device, Floppy disk drive".
Second boot device, "CR-ROM" drive.
Third boot device, "Your new hdd".
If your bios does not see your hdd you'll need to re-check the data cable from the board to the drive. (Make sure it is fully connected).
If the drive is an IDE/PATA make sure it has power. A 4-pin molex.
010e000.jpg Good luck ipackrat21!
Still have trouble, post it here.
Mike
Jan 14, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Gateway MS2285 15.6in Laptop X2 2GHz 4GB 500GB DVDRW Logo
46 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
