Question about Saws
How to lift saw blade. My saw is many your old and bought for another. I now need to use it but do not know how to lift cutting blade
    Sergeant:
  • 192 Answers
The bed moves down so that less blade shows on a skill saw. The locking lever is usually between the blade guard and the handle. Look for a lever and pull it up to unlock, then move the bed down to expose less blade, then push the lever down to lock the bed in place. Please supply a picture of the saw you are using.
Posted on Apr 26, 2015
  • 271 Answers
SOURCE: how do you ulock the saw to pull up the blade so you can put the wood underneath to cut
push down gently on the arm and reach around to the rear of saw with your right hand and pull retainer pin the arm should release and allow usuage of your saw.
Posted on Oct 24, 2008
  • 33 Answers
SOURCE: dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Posted on Feb 13, 2009
  • 376 Answers
SOURCE: instead of cutting, my saw burns the wood and makes
Sounds like a very dull blade.
Posted on Jun 30, 2009
VtToolMan
  • 704 Answers
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need to get a replacement saw blade guard for an
you can try going to Dewaltservicenet.com and locating it that way but with only the serial number it would be impossible. Is there any numbers on it to indicate the model or partial model and you can pull up breakdowns that way.
Posted on Dec 13, 2009
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
Jammed my 6230 bandsaw during a cut and now it won't start. Are their fuses I can replace?
Go to Milwaukee Tool website and try to check if you can download a manual or electrical diagram there. You can call or email them. Check the motor capacitor.
Are you using an old or new band saw blade? If it's old/dull, try different blade. If it's new, the weld might be really bad. Old Blade and Bad weld can cause the blade to jump off. I purchased band saw blades on www.sawblade.com . Great quality blades; they have porta band blades. Call them.
Oct 23, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
I have a 12" Ridgid
if it is only 2 months old take it back and get another one. if this not an option try some loctite on bolt
Jun 27, 2011 | Ridgid Reconditioned 12 In. Compound Miter...
The diamond insert in the hub of the blade keeps falling out as soon as I start a cut. What is wrong?
DO NOT USE SAW!!!
1. switch off saw, remove cord from socket (positive electrical insulation)
2. lift table for maximum cut and check size of the washer holding the blade,
3. you should have holding nut with collar, collar is about 1 1/4 (32mm) diameter, then blade (diamond is actually universal reducing bush in some blades) and lastly you should have internal washer, again, about 1 1/4" (32mm) diameter. if your collar are smaller, you need to replace blade as not suitable for your particular model, albeit I am rather suspicious that you have wrong collared nut and internal collar. Please check if both collars are exactly this same diameter. Please check if collars cover diamond cut-out.
4. if you see discreptancy between description in 3, purchase suitable blade (external diameter is 7 1/4" (184mm), as you did not supply what model of your saw, therefore most probably shank is 5/8" (16mm),
5. mount internal bush (collar), will go correctly only in one way.
6. mount blade (pay attention to cut direction, cutting surface should be clockwise if you look at mounting shaft.
7. mount external flared nut
8. check blade for slippage and wobbliness
9. connect power cord and switch on/off
10. check saw blade againg for slippage/wobbliness
11. make test cut if 10 was correct
12. use normally
Do not forget that this is not a toy, it will cut through wood, ocassional nail and your fingers.
Opearating saw crate flying debris, always wear googles or facemask, you have only two eyes and there is no spares.
Please leave note how you go with this advice.
Aug 18, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
I have an old craftsman table saw. i believe the "brake" or gears a shot. the saw runs very loud and shakes. now no matter how much i tighten the blade the nut loosens after one cut.
With the saw unplugged and the blade tightened, using your fingers try to wiggle the blade side to side and lift it up and down. Other than a little flexing of the blade, there should be no movement. If you have much movement you have a problem and the saw is dangerous. If this is a belt-driven saw, then you may be able to replace the bearings on the arbor (the shaft the saw mounts to) or you may have to replace the whole arbor. If this is a direct-drive saw (the saw mounts directly on the motor shaft) then the bearings that have failed are in the motor and you are less likely to be able find and install replacement bearings. If you find the model number of your saw, you might be able to find drawings and replacement parts on this site:
http://www.searspartsdirect.com/
Thanks for using FixYa. Let me know if I can help more. Good luck. Al K
Mar 14, 2010 | Craftsman 10" Table Saw
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
I HAVE THE JET 414458 HVBS SAW.THE SAW CUTS ROUND STOCK CROOKED.IT LOOKS LIKE THEBLADE IS IN CONTACT WITH THE STOCK AT THE START OF THE CUT AND ABOUT .250 AT THE END OF THE CUT THE STOCK IS 1" IN DIAMETER
There are two possible reasons for your band saw to cut crooked.
1 is the set on one side of the saw blade has worn down and you need to change your blade, or
2 your band saw blade is not square to the bed of your band saw.
If the blade is brand new and it still cuts crooked then you need to square the blade to the bed. To check if the blade is square to the bed, lift the head of the saw up a couple of inches and take a square and set it on the bed. Slide the square up to the blade and to see if there is a gap between the edge of the square and the blade. Try to pick a spot on the blade where the tooth is straight or bent away from the square. If there is a gap you'll need to move both blade supports in or out until there is no gap between the edge of the square and the blade.
If you are unable get it squared yourself, contact the place you bought the saw from. They maybe willing to send a service tech out to do it for you. Some band saw blade makers are also willing to send a service tech out to correct any problems that you may have. Lennox is one such company that may send a service tech if you are using their blades.
Hope this helps you,
Hatter1
Mar 06, 2009 | Jet 414458 HVBS - 56M Horizontal/Vertical...
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Grinder problem
* The base plate can be tilted to make angled cuts. Most saws adjust from 90 degrees to slightly less than 45 degrees, making it possible to cut bevelled ends on boards for corning attachments, hip-roof rafter cuts, and even miters. Most saws are equipped with a thumbscrew or lever to loosen the bolt which keeps the saw blade on the correct angle for the cut you are making, located on the front of the saw. Some are also equipped with a scale which indicates the blade angle, from '0' (90 degrees, or square to the board surface) to 45 degrees. * The blade can be set to the depth required for individual cuts, from less than 1/8 inch to the full depth the blade is capable of penetrating. The lever or thumbscrew which locks the base plate at the desired height is usually located at the rear of the motor on the left side. * Many circular saws are equipped with a ripping fence, to guide the blade as you make a rip cut along the edge of a board, giving you a straighter, parallel cut. * Dust ejector. A few newer saws are equipped with a dust ejector to blow the sawdust away from the operator's face and from the mark where the cut is being made. * Laser tracking light. Some newer saws are equipped with a laser that projects a bright, red line down the path of the blade travel. These can also be purchased to retrofit on older units that are not factory equipped with them. * Blade guard. This should be considered a essential safety feature on any saw, and has two parts, the fixed guard over the top of the blade, and the floating guard, which rolls out of the way as the saw is pushed into the work piece. Some have a handle so the blade guard can manually be lifted for plunge cutting or easier viewing of the cutting mark.
Aug 27, 2008 | Speed CGW ABRASIVES 35587 "24-GRIT" HIGH...
I just purchased a Hitachi C12LSH. The blade hits the guard in the cutting trough. How do you move the saw blade to center it?
you should be able to adjust blade up a little bit, you only want blade to cut through tile bout 1/4 inch ,should be big knob you lossen to lift up motor and blade good luck
Aug 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
Saws Logo
338 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
