Question about Cell Phones
Lg-E435k keeps freezes when on - Cell Phones
I have a lg g pad 7.0 and it keeps freezing on me how do i get it to stop freezing up?
Sounds like a software issue. If possible see if there is a update for the device. That could help with the freezing problem.
Dec 02, 2014 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
Lg gw300 keeps freezing and crashing on me phone is only 3months old
Hi to solve this you have to contact lg service center and tel them about this they will help you
May 11, 2010 | Cell Phones
LG LFX25960ST refrigerator food freezing above the pantry draw. Made all the tempature adjustments and still happening.
I have the same problem and I know the solution.
For LG to get their "in the door icemaker" to work, they have to blow cold air into the door's icemaker compartment. This air travels through two vents located just inside the refrigerator on the left side. The problem LG has is that the seals between the door and the refrigerator for these vents leak. This means that cold air is vented into the refrigerator compartment. Any sensitive food placed on the bottom two shelf on the left side will freeze. I can place two bowls of water in my refrigerator and make ice in 6 hours, even though the refrigerator is set to 38 degrees. The good thing is that LG knows there is a design problem and they know they can not fix it. After calling LG repairmen out for my freezing problem and not getting the seals fixed, LG gave up. Of course LG will try replacing the seals, and then replacing the door; but the real problem is a bad seal design. Just keep putting bowls in your refrigerator and as long as they continue to freeze up, keep calling LG back and demand that they fix the problem. LG can not fix the problem because it is a bad design, so now I am getting a new refrigerator Model LFX 29927, which is better and has dual icemakers. If you an LG refrigerator with their in the door icemaker, place two bowls of water inside the refrigerator, and if your seals are bad and they freeze; complain to LG until they give you a new refrigerator.
Nov 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Lg viewty phone keeps freezing when i click on my
hi
my hunch is that the my files is located on the Memory card and the memory card is faulty try removing your memory card and accessing your 'My Files' if this works then you may have to replace your memory card
cheers
pls rate if this works
Jul 13, 2009 | LG KU990 Viewty
My LG VENUS keeps freezing!!!
i would guess that when you droped it you knocked something loose is it still under a warenty? if so i would return it for a new one if not take it into a shop
Jan 10, 2009 | LG VENUS Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
