Question about GE Refrigerators
GE refrigerator model GTS18DC. Freezer is as cold as it should be. The refrigerator isn't getting cold. What could this be? Thanks!
  • GE Master
  • 932 Answers
I would suggest using a hair dryer instead of chipping ice out of the way. You can damage the tubing way to easy and then you have big problems. It sounds like you are having a defrost issue and that could be your defrost timer, the defrost heating element, or the defrost thermostat. The heating element is usually the easiest part to check and all you need to check it is a meter that you can do a continuity check. Some of the newer refrigerators have the defrost timer on a circuit board now and you can only correct that possible problem by replacing the board. The thermostat can only be properly checked for continuity while it is below freezing temperature and then warm it up to see if you loose continuity. Hope this helps!
Posted on Apr 13, 2015
    New Friend:
Freezer blows cold air to fridge, sometimes freezer freezes at back and blocks holes for outlet to fridge, defrost and restart, or take back panel off freezer and chip clear
  • 4 Answers
SOURCE: GE Model TFX25KRCGWW there is frost in the freezer
Just went throught he same thing. The evaporator coils ( the ones in the freezer section) have defrost heaters that cycle occasionally to keep them frost free and they are not working. It could be the defrost thermostat, defrost timer, or the heater elements. The timer is the first thing to check followed by the thermostat and then the heater elements. Advice, help, and parts are available along with detailed diagrams of the refrigerators at several web sites:
http://www.appliancepartspros.com/partsearch/
http://www.repairclinic.com/Home.aspx
http://www.pcappliancerepair.com/
http://www.partselect.com/default.aspx
Posted on Apr 18, 2009
  • 24 Answers
SOURCE: Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Posted on Jul 28, 2009
SOURCE: MY GE GSH22JFTABB WONT GET COLD
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
iwillfixforu
  • 619 Answers
SOURCE: GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Posted on Mar 07, 2010
heatman101
  • 43501 Answers
SOURCE: refrigerator and freezer not getting cold side by side
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 25, 2010
I have a gts18dc Ge fridge and the freezer is too cold just replaced the evaporator fan motor
Hello:
What do you mean "Too cold"?.. normal operating temps are:
Freezer : -5 to 10 F,
Ref : 34 to 40 F
Jul 17, 2017 | GE Refrigerators
I have a GE Profile PDS22MCR bottom freezer. The freezer is getting colder and the fridge is getting warmer....... What could this be?
your damper assy isn't opening to allow cold air from the freezer up into the refrigerator,its located on the rear wall in the refrigerator compartment,you need to make sure theres a fan running in the freezer,then if so you should feel cold air blowing up in the refrigerator compartment,remove this panel and see if its shut,if no air is felt then the damper door is either broken or jammed shut or if its o.k.,then your control board in the rear of the unit could be defective not letting power to the damper door or even on of your thermistors in the side walls of the refrigerator that monitor temps in the refrigerator and freezer could be defective
Sep 28, 2012 | GE PDS22MCR Bottom Freezer Refrigerator
GE refrigerator isn't cold at all
you need to have the frig defrost the passage is in the back going from the frig to the freezer so if it is frosted in the back than the air is not moving correctly
Sep 18, 2012 | GE Refrigerators
It seems that the wiring diagram show the hot/black side going to the defrost timer AFTER the cold control/thermostat. how does the timer keep running when the cold control isn't...
If your model is the PSS26MSRSS the defrost timer is built into the motherboard and will be completely electronic. Click here for the=> Service Manual And then click here for=> GE Profile/Artica Technical Information Now it is possible that the model listed here requesting a solution may have been listed incorrectly by auto generated model numbers and not by your fault, it just happens here at times. So if this is what happened then try again to provide a different model number. Here is how GE locates their model numbers, Click Here=>
GE APPLIANCE MODEL NUMBER LOCATOR'S
Refrigerators
Freezers
  • Chest Freezer
  • Upright Freezer
  • Either way I am here to help and if your model is the model listed you most likely are having problems with either the compressor start components or the motherboard itself. If you would like me to assist you more just let me know HERE or here on Fixya. Seems lately customers are having a little trouble navigating the site due to so many new changes. Hope this helps, so let me know, Thanks, Sea Breeze
Sep 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile counter depth French door refrigerator bottom freezer and I keep getting frost in the freezer. The seal on the door isn't as tight as the seal on the refrigerator but no cold air...
Where are you getting frost at? Is it on the back wall in the freezer? if so - your problem may be a defrost issue and in that case you would need to hire a professional appliance repair technician to service your refrigerator.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
Aug 29, 2011 | GE Profile PDS20SFSR Bottom Freezer...
The freeze has ice build up on the back wall and the temperature isn't cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Model GSS22SGRF refrigerator. The freezer is cold but the freezer isn't staying cold. Any suggestions?
heatman101
May 23, 2011 | GE Refrigerators
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
