Question about HP Photosmart C5180 All-In-One InkJet Printer
I am trying to print a 5X7 invitation. The printer begins to pull the card to print but then gets jammed. I've selected the correct paper size but this had not fixed the problem.
    Habit-Forming:
  • 15 Answers
A4 paper works normally remains 5x7 paper tray or if it remains stuck in the printer tray rollers that pull the paper check is not dirty you can clean with water and a cotton ear
Posted on Apr 13, 2015
  • 10 Answers
SOURCE: print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Posted on Oct 06, 2007
map9966
  • 2351 Answers
SOURCE: Printing Business Cards on Cardstock
Yes, the roller system will only open wide enough for semi thick cardstock. If you read through you're manual you'll find the recommended card stock you can use. HP supports HP paper.
Here is a list of supported HP paper.
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=16118&lc=en&cc=us&dlc=en&dest_page=product
See the user manual on page 45.
Papers to avoid when printing
It would not hurt to remove the rear door & clean the rollers. (No soap). Dried soap film will cause paper to stick to the rollers. You can go to Wallmart or a local hardware store & buy a bottle of Grease Lighting. This heavy duty cleaner (When dry), does not leave any soap film. Great for cleaning just about anything.
If you wish to download the user manual from HP (It's easer to see & find information faster. Just click on this link:
http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Good Luck!
Mike
Posted on Jun 13, 2008
  • 105 Answers
SOURCE: printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Posted on Nov 05, 2008
greg_margo
  • 1959 Answers
SOURCE: Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Posted on Apr 20, 2009
SOURCE: paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Posted on May 13, 2009
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
How can I print invitations size 5X7 on this printer.
You need the driver setings on your pc, select the correct paper type or media type then select the size if this size is not available you can create a custome paper size one the driver but you must take into consideration on how thick is your paper you can set the media thicker setting all this option is available on the printing preference (windows) or print settings (mac).
hope this help
May 11, 2010 | Epson ACULASER CX11NF All-In-One Printer
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Faded printing on 5x7 size paper
Sure. One of the papers is probably clay based (Shiny) and one is rag based (rough and dull). Clay based produces the most vibrant inkjet images and rag based produces the best laser printer images. I bet the two papers are different in composition. I see this all the time.
Mar 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Paper size
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Printing 5x7 invitation
use the mpf tray. go to the machine press menu down arrow untll you get to tray settings. right arrow over till u get to paper type...then down arrow till you see paper size...right arrow again till u see tray 1...down arrow till you see mpf..right arrow till you see letter. Now that you are in the mfp section you can down arrow and you will see serveral selections I would keep it at letter. when you select it an * will appear next to letter. Then select menu and you and the printer is set. Now go to the print option in the program that you are using and when the dialog box to print opens select properties. go to paper quality the mpf should be selected in the tray souce. Now go down and you will see the advance button, click on that you will see Paper/Output make sure it says Paper Size and Letter is selected. Media Type should say Plain 1. If the invitations is on a heavier paper like card stock click the down arrow and select Covers 1 . If your paper is coated like matte finish photo paper select Coated 1. Now click ok. Do a test print and see if you get what you want. If not, let me know.--Deeva
May 21, 2008 | Dell 3100cn Laser Printer
Paper mismatch
Hi kingwa55,
Click on custom
Then Click
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Adjusting paper size guides
Adjust paper guider, if not see media size support or not ....
Mar 15, 2008 | Samsung Laser Multifunction Printer Toner...
Print 5x7 invitations on my 950?
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
41 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
