Question about Garden
U have a Deere gx 345 it has a short that I can not find . Every time u think I have it it fries the large board on key switch with the fuses in it. Burns part often board on back side.
  • 9 Answers
SOURCE: john deere mod 345 no spark
first find the wire that is grounded to mower to ignition
and check that it is isolated if mounted on some plastic and disconnect it
if it runs to start switch check wire for cuts also
most common problem is the coil located under the top plate held on by 4 /5 screws on sides.
remove top and follow plug wire back to coil
you can clean the curved edges of coil that are against motor {magneto} with sand paper and clean mag
remove plug and lay threads securely agains frame and check for spark {hold by wedging not by hand as you can get a jolt!}
Posted on Aug 20, 2009
nova2nv
  • 197 Answers
SOURCE: our j-d 345 lawn mower tries to start but it seems
Time delay module?Does it seem to crank faster?
Posted on Nov 13, 2009
SOURCE: INSTALLING THE MOWER DECK ON JOHN DEERE 345
Can't help you completely but I believe the brass colored bar coming from deck towards front should be on top of the black bar that puts the tension on. I had it on the bottom and the both bars ended up under the deck.
Posted on May 13, 2010
SOURCE: My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Posted on Dec 31, 2010
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
JD 345 pto will not turn on.
What you need are wiring diagrams, not schematics, and you will have to inquire directly to John Deere.
Jul 20, 2016 | John Deere Garden
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
How do I diagnose ignition problems on 345 with 20 horsepower Kawisaki
disconnect the ground wire from switch. if still no spark then your coil is no good. if you get spark now then you have a short in your ground wire or switch
Sep 18, 2014 | John Deere 325 345 Tractor Service Pricing...
John deere gx 75 losses spark
Loosing spark,and a no start are two different issues! If it's a no start,no voltage to the starter,the it's a bad switch,bad connection or a BAD GROUND ! clean all connections.
Jun 22, 2014 | Mtd Garden
Lost power to Ignition,power window's and heater all at the same time.Hooked up switch to over ride ignition so I could start it and that worked.Is there any other fuse's besides what's in the...
There are special wires called fuseable links that protect the major circuits such as the key switch. It sounds like you fried one of them.
The wires are usually connected to the large post on the starter. If you did fry one of them, you'll need to track down the short before you repair the wire, otherwise it will do it again.
May 28, 2013 | 1995 Pontiac Grand Am
John Deere 345 won't shut off
I would start with either replacing the key switch, or tracing the wires to make sure they are not touching together somewhere, completing the ignition circuit.
Apr 14, 2013 | Garden
JD 345 Having problem with ignition coil or ignition pulse. How do I check each? When it warms up the left side cuts out and may eventually stall. I pull the plug wire off it doesn't make any difference...
I have a Gx 345. Had a very similar diagnostic issue. Make sure you have a fresh set of plugs and have checked wires for abrasion. The best way to see, if you have a grounding out issue is to start tractor in the night and look for sparking on each side of engine.
Anyhow, after replacing ignition circuit board, the problem was corrected. Coils fail very rarly, if failed they simply don't work. Typically, an intermittant problem would point to circuitry or grounding issues.
Jul 07, 2010 | John Deere Garden
Our j-d 345 lawn mower tries to start but it seems
Sep 26, 2009 | John Deere Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
