Question about Microsoft Xbox 360 Console
360 is flashing 3 red lights
I need help with this problem i have as u aready know my xbox 360 is not working, when i turn it on 3 red flashing lights come on and it doesnt boot up please help me thanks Mike
  • 34 Answers
Unfortunately there is nothing that you can directly do to fix this problem without voiding your warranty,. This means that if you attempt to repair it and fail MS will not fix it for you.. The "Fix" posted by others SOMETIMES works, but NOT ALWAYS.
Pleae be careful with your expesive gear!
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
Posted on Nov 16, 2007
  • 30 Answers
If you have had your X-Box for under three years and have this problem, there is good news. microsoft have brought an enhanced warranty with the three red lights. i would get in touch with microsoft and have the repair it or send you a new X-Box out.
Posted on Nov 14, 2007
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in to microsoft.
Jan 23, 2013 | Microsoft Xbox 360 Console
What to do if you have 3 flashing red lights on your Xbox 360 Console?
If you have the 3 rings of Death (3 Flashing Red Lights) on your xbox 360 console, all you need to do is to contact Xbox Support and report this issue with them. The Console has a 3 year warranty for the 3 flashing red lights. Just make sure you did the following first:
1. Power Cycle your Console (Turn it off, unplug the power adapter from the wall outlet, wait for 30 seconds, turn it back on)**This is the best solution and it usually works!!
2. If still persist, Turn it off, remove any accessories connected to it (Hard Drive, Controllers, etc.) turn it back on without those accessories. **These accessories sometimes causes the problem.
3. If removing these accessories removed the 3 flashing lights, attach the accessories one at a time, every time turning it off and attaching one and turning it back on checking each time if the red lights (any lights) appeared. It will tell you what is causing the error.
4. If all else fails, again CONTACT XBOX TECH SUPPORT on their Toll free number. Make sure that you tell the tech that you have done those things above so they can create a report for the issue. They love the 3 flashing red lights issue. I should know, I am formerly one of them. :)
on Jun 12, 2010 | Video Game Consoles & Games
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1& follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Three red lights
Follow this steps:
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Good Luck
Apr 03, 2009 | Microsoft Xbox 360 Console
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at to know more information on fixing your xbox
Jan 07, 2009 | Microsoft Xbox 360 Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here:
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
3 red lights
it means you have a lose wire
Jan 04, 2009 | Microsoft Xbox 360 Console
RED lights flashing
This is going to sound like a very strange solution, but it worked for me, twice. My xbox 360 gave me the red ring of death once, and in my despair I asked a few friends about anything they can think of, and one suggested letting it run for 10 minutes while wrapped in a towel, or blanket. By that point I was desperate enough to try it (I had bought a refurbished one, so it wasn't under warranty anymore), and lo and behold, my xbox 360 is as good as new. Basically what you're doing is shocking the system into working via overheating... I know that doesn't make much sense, but, like I said before, it worked twice for me. Hope this helps!
Jul 27, 2008 | Microsoft Xbox 360 Console
Console with 3 red flashing lights
iv noticed that my xbox started flashing red and froze so i turned it off immeditly and felt the connections in the back were really hot and my xbox was really hot so iv moved it to an area where it could get good ventilation and keeps cool. havent had any more problems turning red it blows out alot of hot air out the back it needs to breath.
Dec 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
