Question about Food Mixers
Where can I find a owners manual for a soundtech mixer model:pc-830
  • Food Mixers Master
  • 1,314 Answers
Unlikely you will find it in the FOOD mixer area.
Posted on Apr 13, 2015
Owner manual for Cooks stand mixer model #SM248
this page says it has it, but I am a bit concerned that it is a zip file
Download cooks stand mixer owners manual ' Diigo Groups
https://groups.diigo.com/.../download-cooks-stand-mixer-owners-manual-6694925stand mixer Model SM248, 700 watt, 12 speed, 5 qt http://retrorenovation.com/wp-content/gallery/1960-drexel-catalog/drexel-profile-18.JPG Documentation Location Service: Reference Information Report for KitchenAid Classic Stand Mixer KSM5 Service Manual cooks stand mixer owners manual. Service manual for the ...
Cooks stand mixer model SM248 manual Google Search
Feb 14, 2018 | Food Mixers
How do I get an owners manual for Ross mixer 12x2
What model of Ross Mixer do you have?
Dec 18, 2011 | Food Mixers
Cooks model sm 248 mixing parts and break down on parts along with owners manual or opereting manual
i have searched the web and cannot find a instructions Manual for the Cooks mixer Model sm248... any help?
Nov 13, 2011 | Cook's Essentials 700 Watts CESM100 Pro...
I need the manual for my K5SS mixer my
Hi WWW_SOCRAFTI, you can easily download both the Owner’s Manual and Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50PPWH0.pdf (5156.65 KB) from the Owners Manuals (9) list and this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
The reason I suggest downloading the Parts List manual is that should you decide to try and troubleshoot and fix your KA mixer, this manual will be invaluable in the disassembly and reassembly of your mixer along with listing all the part names and numbers. Having the correct part names and numbers is critical when reordering replacement parts when your mixer eventually will stop working.
Good Luck with your mixer, I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Feb 14, 2010 | KitchenAid K5SS Heavy Duty Commercial...
The paddle on my mixer runs too low and hits the bottom of the bowl. any ideas?
Hi ERIN. This should be pretty easy to do by yourself. The instructions for adjusting your beater to bowl clearance is in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case K$45SSW and select the file listed for your model that appears under Owners Manuals (2): K45SSWH-0.pdf (2730.37 KB) and save that file to your PC. Turn to Page 13 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
I hope this helps! – Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Jan 30, 2010 | KitchenAid K45SS Classic Stand Mixer
The wisk is hiting the bowl how can i adjust
Hi FMOINIZ, by the symptom you are describing, you need to adjust your mixer’s Bowl to Beater Clearance. This is quite an easy task, and is explained in your Users Instruction manual that came with your mixer. If you do not have one, you can easily download a PDF version from the KA website at: ’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (4) KP50PSWW0.pdf (2930.74 KB) and save that file to your PC. Turn to Page 11 and you will find the instructions for adjusting the Bowl-Lift model mixer head height.
But to save you some time, I have extracted the instructions below:
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
Dec 26, 2009 | KitchenAid KP50PS Professional 5 Series...
The beater is rubing and the paint is comming off
Hi TCMARTIN. This should be pretty easy to do by yourself the instructions for adjusting your beater to bowl clearance is in your Owners Manual. I you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Dec 20, 2009 | KitchenAid K45SS Classic Stand Mixer
Have a kitchenaid artesian mixer need to adjust beater depth-it is scraping the bottom of the bowl. Model #KSM150PSEr 325 watts
Hi KELLYSERMAN, this should be pretty easy to do by yourself the instructions for adjusting your beater to bowl clearance is in your Owners Manual. I you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66): KSM150PSER1 (732.33KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Dec 07, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I'd like to get some receipes for the mixer
DEBBIE - Your KA Owners Manual should have numerous recipes included. If you don't have the original manual that came with your mixer you can down load a PDF version from the KA website. Paste the following URL into your browsers: address bar: http://www.kitchenaid.com/flash.cmd?/#/page/home
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case K5SSWH), and then select Owners Manual (1)file. You'll need Adobe Reader to open and read the file if you don't already have it on your PC. Save it to your PC. Pages 16-61 have a whole range of receipes.
I hope this helps, Good Luck! Howard, Burke VA
If this solution has helped you, please rate it. hslincoln
Oct 23, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Need owner manual for Sunbeam stand mixer 2350
I didn´t find it with google. Maybe ask the experts from manualfox.com - if they don´t find it, it does not exist.
Dec 15, 2008 | Sunbeam 2350 Heritage Series Mixer
Food Mixers Logo
125 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
