Question about Makita TABLE; 2708 REG - MKA 155506 4
When i turn it off, it skreeches, and chaters to a stop.
    Top Expert:
  • Makita Master
  • 51,298 Answers
Worn or dry bearings or bushes
have it checked out at an appliance shop
Posted on Apr 13, 2015
Yamaha g16 chatering and smoking
Worn piston rings, piston slap and possibly oil too thin.
Mar 11, 2014 | Computers & Internet
I have a 2001 Isuzu Rodeo. When starting, it has a loud skreeching noise and when theres a load on it. I have replaced the belt, 2 idler pulleys, alternator, a dummy water pump pulley, and the ac. Still it...
Typically, the noise comes from the fact that the tension on the altenator belt is not enough. I recommend you tighten the belt by adjusting the tensioner screw by about (2) turns and test. Repeat it as necessary until the noise stops.
You'll usually hear the noise right at start up and it will continue for close to a minute until the idle of the car changes.
Jun 17, 2011 | 2001 Isuzu Rodeo
1992 dodge grand caravan with ABS has a hard brake pedal and hard to stop, it makes funny chatering sound from the hyd control moduel, how can I tell if the modual or the abs motor are bad
A "hard brake pedal" is a sign that the brake booster is not functioning correctly. check vacuum line to booster first, for splits or cracks. if none the master cylinder may be bad.
May 25, 2011 | 1992 Dodge Grand Caravan
When i turn it on it's making a skreeching noise from the back what could it be?
The most common stuff that comes to mind first:
1) one of the rollers (there are 2) has worn out and they skreech as
they're being killed. I've even seen rollers fall apart, with the outer
part of the roller (the rubber part) squeaking as it revolves around a
frozen-on roller bearing.
FIX: replace roller(s) that're making noise
Cost of part: $10
2) the motor bearing are shot - they scream as they're being ground to dust.
Fix: replace motor.
Cost: if dryer is old, replace dryer. If Dryer under warranty, use it.
Oct 23, 2010 | Whirlpool LER4634J Electric Dryer
2002 f-150 super crew 4x4. Truck has a faint vibration when taking off and turning at the same time. Seems to be coming from the rear. Does not do it when taking off and going straight.
Could just be positrac differential.
Mine positively hops into the air when I take a corner too tight while accelerating.
As long as fluid level is good, I would not worry about it. I think it is normal.
Cars don't have this feature.
Mar 24, 2010 | 2002 Ford F150 Regular Cab
Transmission "chater"
Sounds like the flex plate that is between engine and trans may be cracked Have verified by inspection
Jun 12, 2009 | 1993 Toyota Land Cruiser
Wipers and radio quit
The relay is over heating and internally shorting out.
Replace the relay.
Feb 01, 2009 | 1995 Chevrolet S-10 CA Edition
Defrost board contacts in relay chater and do not let defrost
is sensor at proper location? try turning sensor ? Ohm sensor as you turn it.
Jan 14, 2009 | Goodman CLQ36AR49 Air Conditioner
Makita TABLE; 2708 REG - MKA 155506 4 Logo
167 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
