Question about Reebok Exercise & Fitness
My reebok 8400c treadmill wont run???
Iights on console work but fans speed and incline and belt wont work???
    Master:
  • 505 Answers
Check this link for the manual of this treadmill:
Reebok 8400c Treadmill Manual
Treadmill Lights Up But Fan And Belt Wont Run
Posted on Apr 13, 2015
Why does my reebok 8400c treadmill stop after a minute or two? The control panel works, but the tread will stop. I can start it manually, but it stops again after 1 or 2 minutes.
You have to check the speed sensor potion. Try to align the speed sensor or check is there is any dust accumulate on speed sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 27, 2016 | Reebok Exercise & Fitness
Reebok ZR8 display is completely blank. Belt working fine, speed and incline keys still responsive - just can't see speed, distance etc
Hi Adrian, All a treadmill is... is a motor, running belt and console display pad. You'll find the console display pad has malfunctioned.... This can happen when something heavy is placed on it OR something hits it and if yours is under warranty then get it fix as soon as possible mate, I had a problem with my console display pad and it cost me $100 just for the pad....... My treadmill is a different brand but I can tell you the motor and running belt will last and last and last.....I hope this helps.........CHEERS..
Apr 27, 2016 | Reebok Exercise & Fitness
Have reebok 8500 ES has been stored turns on but does not respond to console ,it as if they are not speaking to eachother
Maybe check for a reset button around the motor/ belt drive. Manually roll the belt a little to free up motor if it's been sitting awhile.
Sep 03, 2015 | Reebok 8050 ES Treadmill
REEBOK T 3,2 TREEDMILL INCLINE MOTOR MAKES A BUZZING SOUND AND GETS EXTREMLY HOT, BUT DOES NOT OPERATE.
RUn the software calibration for easy diagnostic, and fix it.
Go under the HOOD motor, and see the steps . or see the steps
God bless you
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 22, 2013 | Reebok Treadmill T 3.2
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Jan 22, 2013 | Treadmill Doctor Reebok S 9.80 Treadmill...
Reebok i run
RUN the software calibration for troubleshooting and fix it.
God bless you
follow the steps.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 08, 2013 | Reebok treadmill i-run pure
I have a Reebok 8400C treadmill. The control panel stopped working .. I get power but no buttons are functioning?
1) replace batteries and clean contacs with c.cleaner, tight the connector very well
2) tight the ribbon cables, clean it, and tight the plug or connector from display board vs lower board, see the b. diagram
3) adjust the REED switch, clean it, and tight the plug well.
God bless you
Oct 14, 2012 | Reebok 8400C Treadmill Motor Control Board
My reebok TR3 Treadmill will powerlift, incline lift and motor runs but the belt slows when I stand on it. Ihas been liubrictaed with Slicon oil and now the belt will nly commence turning if I opush it to...
Maybe the silicon oil is making your belt too slick to get a grip. If you can access the rollers you may be able to remove the excess lube with a cleaning solution.
Jun 18, 2012 | Reebok Exercise & Fitness
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
Sep 30, 2009 | Reebok 8050 ES Treadmill
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Exercise & Fitness Logo
376 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
