The washer goes through the motions to start but door lock keeps coming on?
  • 960 Answers
Looks like a Daewoo? DE means "Door Error" which is usually a failed door interlock switch. With the door open, have a look at the rubber gasket , around this is a steel band with a spring on it. Prise it out with a flatblade screwdriver. Pull the door gasket from the cabinet. (It has a lip that fits onto the cabinet) Push the gasket back into the machine so you can gain access to the back of the front panel. Undo the 2 screws on the right hand side of the door opening, the door switch will then be able to come out. Make sure the machine is UNPLUGGED from the power!. The door switch will have a socket connection to the switch. Pull the connector off and fit a new switch. Its good to mark the connector first as it can go back on both ways. If you put it on backwards, the machine wont work. Refit in reverse order to stripping the machine. The steel band can be a pain to refit as you have to stretch the spring so that the band and spring fit back into the groove it came out of. Get the model number and call up your nearest parts supplier for a door interlock. If you cant find one and you are in Australia, Castel Electronics in Melbourne are the Australian Distributors for Daewoo Whitegoods.
Posted on Apr 13, 2015
5 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Why won't Kenmore model 40272900 washer door lock?
Replace the door lock.
Posted on Nov 11, 2012
beltronic205
  • 1461 Answers
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
Posted on Sep 28, 2009
Krazytech
  • 725 Answers
SOURCE: washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
Posted on Aug 13, 2008
SOURCE: Washer will not start up once you push the button
Make sure the door is closing enough to allow the lock to locate properly,Try this or try replacing switch.Hope this helps.Cheers.
Posted on Jul 29, 2009
Why do my alarm keep coming on when the car is locked
Common problems are the interior motion sensor and the hood switch. Try disabling the interior sensor by pressing the lock button on the key twice and see if it helps.
Sep 18, 2014 | 2003 BMW 7 Series
Door lock on my front loader washer
Hi Terina, thank you for allowing me to assist you.
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If the appliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. Contact a professional to move forward accurately.
Sep 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer
let me know
Aug 12, 2008 | Frigidaire ATF6000ES Front Load Washer
FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Aug 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
INDESIT 1000 DOES NOT START
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
