Question about Performance Teknique Car Audio & Video
I hav a performance teknique icbm894 n it wont turn on but the wire gets hot real fast wut could it b
    Top Expert:
  • Performance ... Master
  • 42,713 Answers
Dead short for the circuit that the wire is connected to
take it in and have it repaired
Posted on Apr 13, 2015
5 Suggested Answers
  • 631 Answers
SOURCE: Performance Teknique wont work!!
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
If you want to try to repair it yourself, read through the following page:
Basic Amplifier Repair Primer
Let me know if you have any other questions.
Posted on Jul 02, 2008
  • 631 Answers
SOURCE: performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Posted on Sep 11, 2008
mshill172
  • 20 Answers
SOURCE: keeps on diagnostic after i turned it on and had it completely wired what should be the problem
have you checked the power ant wire? usualy oarnge this needs to be hooked to a power source that is not on when the power of your vehicle is not on (usualy a fuse block)
Posted on May 11, 2009
  • 37 Answers
SOURCE: what size amp should i get for performance teknique sub-woofers
the amp you have will do the job depending on how may ohm you sub is and can you amp stable to handle low ohm's. you should also check your cabling to make sure its for about a 1500w amp so you dont lose any power
Posted on Sep 17, 2009
Need pin out for a Performance Teknique icbm-9706 i lost my harness
It should be a standard 12 pin wiring harness used in many products.
I suggest getting a harness off another set.
Jan 14, 2017 | Performance Teknique Car Audio & Video
Installation-wiring
Performance Teknique might be able to supply a manual and/or wiring instructions.
Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
Blow out amp
try a basic connection connect
positive from car to positive of amp
ground to ground
and positive of car to remote of amp
see if it turns on
also check the fuses in the car
check for voltage on the wires
May 15, 2010 | Performance Teknique ICBM-782 Car Audio...
Hey I just recently buy a performance teknique
good luck finding one, check ebay, or call Teknique directly.
Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
Why do my performance teknique stereo shuts down when the valume is turned up
You have bad connection to fix it find Ground wire is black color.Then rewire to the chasis Metal.
Jan 12, 2010 | Performance Teknique ICBM-9493TV Car Video...
Keeps on diagnostic after i turned it on and had it completely wired what should be the problem
May 11, 2009 | Performance Teknique ICBM-895 Car Audio...
Wont power on after checking all the wires
HI DUDE PLS CHECK UR REMOTE WIRE IN UR PLAYER .... U MIGHT BLOW THE FUSE .. ... THE CONNECTION IN REMOTE WIRE WILL POWER EVEN THE FUSE BLOW ..
Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
Performance Teknique ICBM-779
You may have a defective speaker or a wiring fault. Disconnect the speaker from the amp and measure the resistance across the speaker wires. The resistance should be near the rated impedance of the speaker.
Jan 27, 2008 | Performance Teknique ICBM-779 Car Audio...
Car Audio & Video Logo
115 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
