After using code 14 to reset, the error displays again
Replace the fuser, do not continue to reset or the machine can catch on fire try this site a fuser unit as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
SOURCE: Sharp AL-1655CS ERROR MESSAGE
The [H4-00] system error popped up when the power went out of the house. I called Sharp Tech Support (1-630-378-3590) and was talking to their Tech Support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * (That's pound, star, C, star) This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
SOURCE: HELP, H4 ERROR
The fuser isn't heating up on time. You could try turning the copier off for 30 seconds and turing it back on again to see if it goes away.
If it doesn't happen, there is a part that has to be fixed on the fuser to correct the problem. Usually it is the thermistor.
SOURCE: My Sharp Al-1655CS Display is frozen
# * C *
Thank you!
Sabharish
SOURCE: My Photocopier displayed error H4 on the screen
Dear sir
H4 signal is fuser unite problem please call a technician they solve this problem.Just we serve problem location because i am not live your area.
Thanks
Tareq
