Question about Miscellaneous
Where do I find a replacement remote for my mtn sliding gate
    Top Expert:
  • Miscellaneous Master
  • 46,460 Answers
Probably through the manufacturer website and support
Posted on Apr 13, 2015
I whant to program my remote its a wejoin for a sliding gate operator wjkmp201 to a universal remote
follow the programming sequence in the user manual for the gate operation
I suspect that the frequency range of the new remote and the gate opener operation may be different and it will not work but try it any way
Sep 01, 2016 | Universal Televison & Video
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
What is wring.?
The programming on your remote buttons probably got overridden. Just reprogram your remote's buttons for the alarm and gate .
Mar 29, 2015 | Building Materials
MY ELITE SL 3000 UL WILL NOT WORK WITH REMOTE. IT WILL WORK WITH THE LOOP. PROBLEM WITH BATTERY OR NEED TO REPROGRAM THE REMOTE, IF SO WHERE IS THE LEARN XMITTER LOCATED PLEASE HELP
Hi Mary, do you have more than one remote for the gate? Your remote needs to be paired with the gate receiver. Normally you need to push a certain button on the control panel to enable learning mode then you press the remote button you want to use. You will have to follow this learning process for your device. Please keep in mind that just any remote will not work with your gate, it needs to be on the same frequency and use the same modulation mode.
Hope this helps.
Oct 28, 2014 | Elite Sl3000 1hp Slide Gate Motor,...
How do I sync a Chamberlain remote 371LM to a Chamberlain gate opener Elite Robo Slide?
There are two possibilities. The first and easiest is a sync button on both. Much like a Wii remote, you might be able to find a sync button (most likely small and indented) to have both devices search each other out. The other possibility is registering the remote to the gate. You may have to call in and have help, including giving find and giving the remotes code.
Elisa Jed ' http://abfabrications.com.au/fences-gates
Jul 19, 2014 | Home Security
My gate starts to open but then stops
Need more information.
Firstly, engage the manual release inside your motor and then operate gate by hand. Pay attention to any spots that are hard to push, this would indicate some sort of mechanical obstruction causing the motor to stop. Try remove obstruction.
Secondly, measure the voltage on your battery while trying to operate the gate. If your battery drops below 11.5V the control board will shut down. If so, replace battery.
Feb 04, 2012 | Apollo 7000etl Slide Gate Opener Plus 2...
Beninca Sliding gate
YOU NEED A TECH GUY TO SEE WHAT IS THE PROBLEM.
Dec 18, 2011 | PSB Home Security
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Sliding gate will not close
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Miscellaneous Logo
128 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
