Question about Whirlpool Ovens
I have a whirl pool double oven model# rbd245pdq12 an the conto board is out. Can I install a control board from a whirlpool rbd275pdq1
  • 960 Answers
A lot of ovens use the same boards to reduce inventory / spare parts, but it may have different programmes. The only way to check is to look online to see what programme differences (if any) are between the 2 models and then if you already have the board is to physically check and see what differences (if any) are between the 2 boards. Look for similar part numbers or code numbers on the board and connections, plugs, etc If its the same, try it and see if it works.
Posted on Apr 13, 2015
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: Cleaning cycle stuck whirlpool rbd245pdb1
whirlpool self-cleaning electric built-in oven #RC8400XAB serial # XD1301008. Self-cleaning lever locked. How can I release it???????
Posted on Jun 20, 2008
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
Tip
How to Repair Whirlpool E6 F2 Oven Code
Your Whirlpool Built-in Oven has failed and the electronic control is no-longer-available. You can have this control board rebuilt!
The common symptom is a display that intermittently goes blank, accompanied by an error code E6-F2. This is caused by a failure in the electronic control board (EOC).
The courteous technicians at www.fixyourboard.com in Austin Texas can rebuild this for you!
Control Board Part Numbers: 8302967, 4451856, 4451991, 4452890, 4452898, 4453664, 4453664.
Applicable Models: GBD277PDB6 GBD277PDB7 GBD277PDB8 GBD277PDQ6 GBD277PDQ7 GBD277PDQ8 GBD277PDS6 GBD277PDS7 GBD277PDS8 GBD277PDT6 GBD277PDT7 GBD277PDT8 GBD307PDB6 GBD307PDB7 GBD307PDB8 GBD307PDQ6 GBD307PDQ7 GBD307PDQ8 GBD307PDS6 GBD307PDS7 GBD307PDS8 GBD307PDT6 GBD307PDT7 GBD307PDT8 RBD245PDB11 RBD245PDB12 RBD245PDB13 RBD245PDQ11 RBD245PDQ12 RBD245PDQ13 RBD245PDS11 RBD245PDS12 RBD245PDS13 RBD245PDT11 RBD245PDT12 RBD245PDT13 RBD275PDB11 RBD275PDB12 RBD275PDB13 RBD275PDQ11 RBD275PDQ12 RBD275PDQ13 RBD275PDS11 RBD275PDS12 RBD275PDS13 RBD275PDT11 RBD275PDT12 RBD275PDT13 RBD276PDB11 RBD276PDB12 RBD276PDB13 RBD276PDQ11 RBD276PDQ12 RBD276PDQ13 RBD276PDS11 RBD276PDS12 RBD276PDS13 RBD276PDT11 RBD276PDT12 RBD276PDT13 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDS11 RBD305PDS12 RBD305PDS13 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDS11 RBD306PDS12 RBD306PDS13 RBD306PDT11 RBD306PDT12 RBD306PDT13
on Aug 17, 2015 | Ovens
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
My whirl pool oven is heating even though it has not been turned on. Seems to be from the upeer element.
Sounds like the broil relay on the control board is welded shut. The board can be rebuilt at www.fixyourboard.com
Jun 26, 2010 | Ovens
Whirl pool single oven AKP 510
there is a thermo fuse on unit most often on back or control panel
Aug 13, 2007 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
