Question about LG Computers & Internet
We just replaced a wireless router, now my LG 70 won't connect to my home internet.Searches but says avoided poor internet connection yet signal strength is good.
    Problem Solver:
  • 10 Answers
Go into settings and change the channel BAND - make it to channel a,b or g or all together in one selction. you can find the channel settings in administrattion part of your router. Also check if security password is applied or not. check these settings on all devices.
Posted on Apr 15, 2015
raevenzero
  • 53 Answers
SOURCE: Poor connection with Belkin MIMO G+ router
I would honestly suggest a new router. Although, you could check through the settings on your router and see if the wireless signal is lower then 100% for some reason. Also, see if is blocking any ports. A lot of new router's firewalls will lock a lot of ports down if it sees a virus or trojan trying to communicate outward, so do a scan on all of your computers. You can also try holding the reset button on the router for 30 seconds (you will need a pin or something small), then reconfiguring and using it and see if that helps.
You can also go through this website to try and update the software on your router.
http://www.belkin.com/support/article/?lid=en&aid=5947
Posted on Nov 05, 2007
Dionnow
  • 61 Answers
SOURCE: Router connections
If you have a laptop in home 2 that is able to connect with NO issues whatso ever I would almost think its a security issue... Do you use the same kind of encryption on both home 1 and 2? (ie WPA or WEP)
Posted on Dec 31, 2007
Rajan Solank
  • 62 Answers
SOURCE: computer and wireless router being connected but no internet
To reset the Modem all you have to do is to get a Paper Clip or any object that is like a paper clip then just turn your router to the place where the LAN cables are and just nearby you will see a small button that is abit hidden , so just press that and while pressing it for 5seconds, remove the power cable and plug it back while the clip is still being pressed in the reset button.
Remove that clip from there and you should be able to see that your power light on the router is blinking, wait till it get stable, then all you have to do is login with going to 192.168.1.1 then enter the default username and password which is either admin, admin, or root, password. or root, admin
Then just configure your router again and all shall be well.
THanks.
Hope this helped you.
Posted on May 26, 2009
  • 244 Answers
SOURCE: have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Posted on Jun 28, 2009
  • 415 Answers
SOURCE: Hi, I'm having problems connecting
1. did you first try to connect to the router via wire directly with it in the same room? then set up the wireless to work in the same room too.
2. once you've done that and it worked then move it to your bedroom. If it doesn't work there it could be that there is something inbetween the two rooms that is blocking the signal...ie a furnace can do that
3. if it won't work try relocating the router to another location. Try a different location in the same room first
but as i said , first get it set up and running in the same room so you know for sure it works.
Posted on Mar 21, 2011
How do I get it on my wifi network? it keeps telling me it is avoiding the network because of poor internet cinnection.
If you have poor internet connection problem with your WiFi, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.com before and after following these steps.
Dec 25, 2014 | Tablets & eReaders
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Can i use my WRT120N on neighbors WiFi Network
Hello there,
You cannot use this router to connect to your neighbour's router wirelessly. It is possible to share your neighbours internet connection with this router, only if you run a cable between. You will need a Range Extender or a Wireless repeater for this purpose.
Feb 28, 2014 | Linksys WRT120N Wireless Router
My KC550 lg does nt run internet .I received settings also but it give s communication error.why?
First what is a KC550 lg , laptop , deskop , mobile phone.
Im assuming phone have you synced with the wireless router ?
Connecting your LG phone to wireless Internet is easy to accomplish with phones that can receive Wi-Fi signals.
You may decide to use the Wi-Fi capabilities in the event that you do not receive the best signal from your wireless provider at your home or office.
If this is the case, then hooking up to a Wi-Fi network near you could provide you with a faster connection to the Internet and a more reliable signal to send e-mails, texts and pictures.
Press the "Applications" tab on the home screen of your phone.
Scroll down the list of applications until you reach the "Settings" option.
Press "Settings" to bring up the menu.
Locate and click the "Wireless & Network" or "Connections" option within the "Settings" menu.
Select the "Wi-Fi Setting" or "Wireless Manager" option, then select the network that you want to connect to and click "OK."
All of the available wireless networks within your range will appear.
Enter the wireless network password (usually located bottom of router) if you are connecting to a secure network.
Press the "Done" button followed by the "Connect" button.
Jul 26, 2013 | Computers & Internet
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
I cannot connect my Wii to the internet. Is there a part that I need to connect, or is there something else that I need to do in order to get the wireless connection working?
Here is a step by step instruction on how to connect your Nintendo Wii to the internet. Please note that connecting the Wii to the internet does require a wireless connection, or wireless router for a signal.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
copy and past this into your internet browser.. if you should receive an error for any reason, here directions and a link to solve it.
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
http://www.nintendo.com/consumer/systems/wii/es_na/windows/error51030.jsp
Sep 03, 2011 | Nintendo Wii Console
I have bought a new laptop and are not able to connect to the internet
The wireless router makes computers that already have an internet connection share signal with another computer. For example, the new computer would still not have an internet connectin. Power on each devices of computer and routers to make the next process achievable. For example, the router searches to acquire any available networks either as locall to internetworked diaplayable on the wireless area logo on the computer settings. Once recognised, local or network signals require request to below as new computer device setup. Usually another computer entity has to be notified of intent to capture signals with new ware. Contacting a wireless network provider guarantees the signals connectivity amongs several resources that makes an experince between devices achieveble. Locate either telephone network establishments to ascertain the requriements to establsihing a new network of devices. Prior to contact the network establishment, ascertain the computer devices brand, pertinent details that would make estabsihement effective.
Feb 14, 2011 | Belkin (54G F5D7230UK4) Wireless Router
Have wireless router in other room PS3 setup can't connect www
  1. Make sure that your wireless Internet is turned on and working properly.
  2. Step 2 Turn on the Playstation 32.gif game console.
  3. Step 3 Access the "Network Settings" screen under the "Settings" screen in the main menu.
  4. Step 4 Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
  5. Step 5 Select "easy" on the new screen that pops up asking what type of installation you want to use.
  6. Step 6 Select "wireless" when it asks you what type of Internet connection you have.
  7. Step 7 Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
  8. Step 8 Select your home Internet when the screen pops up displaying the available Internet options.
  9. Step 9 Save your settings on the next screen.
  10. Step 10 Test the connection to make sure that it works properly.
Apr 11, 2009 | Linksys WRT610N IEEE 802.3/3u IEEE...
Linksys Wireless not able to connect to internet
Try it with Mozilla Firefox. If it works try some searches with IE, Windows ME and wireless as search terms.
Jul 09, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Computers & Internet Logo
151 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
